Remove the spark plug and see if coolant comes out when cranking the engine,if no coolant spews out ,it may just be the decompressor isn't working properly. Camshaft may be out of time ,also.
Either way, you're going to half to remove the head again and find out why you keep getting coolant in the cylinder, he may have bought a junk cheapy head gasket or not used the proper torque sequence on the head.
