Old 02-01-2012, 04:17 AM
19flyboy66's Avatar
Member #22873
fuel? in the breather box
I went out to start my ride and it seemed to not want to. I took the breather cover off to find a pool of fuel in the box. What the heck? Can someone help me, I want to get this done before it snows again.
Old 02-01-2012, 04:22 AM
tt425's Avatar
Member #3687
Welcome to the forum. Idk what size and year you have but if it has a carb on it more than likely the float needle is stuck or worn out. Remove carb clean and replace needle seat if worn out. Clean air box,let filter dry or replace. Check engine oil if its a 4 stroke. If it floods bad gas will get into the oil. If smells like gas change oil and filter with recommended fluid.
Need more info on your atv. Year,size,etc?
Old 02-01-2012, 04:31 AM
19flyboy66's Avatar
Member #22873
Thanks, it is a 2001 Scrambler 500 and I will do the oil change but will probably have a shop do the carb work, I don't have the confidence.
Old 02-01-2012, 04:59 AM
tt425's Avatar
Member #3687
It should be the carb if not the only other possibility is the camshaft. I would just about put money on the float needle stuck or bad. Has it been sitting over a month. If it has the carb is the culpret.
Old 02-20-2012, 04:51 PM
09scrammy's Avatar
Member #14330
mine did the same thing today, mine is an 09 scrambler with under 500 miles. Mine also will now run fine without an airbox lid. I tried cleaning and already clean carb, changed out slide spring with the dynojet one and the spring. No more fuel in airbox so far, but still runs fine with no lid. No clue what is goin on. Also will run without air fliter and without lid. If the carb relies on vacuum, it must be getting it from somewhere but where?
atv why gas is entering the air filter box
fuel breather box
gas going into the breather box
polaris 425 crankcase vent tube
polaris scrambler gas in breather box
polaris scrambler oil breather
polaris what does a breather box do on an atv?
scrambler 500 air filter smells like gas
why air filter smells like gas atv
why does my atv smell like gas
why does my polaris have gas in the breather box
breather fixxed ? lawnboy2121 Polaris XP 3 09-29-2011 09:10 AM
tranny fluid comin out of breather razzy2364 Polaris Scrambler 1 09-12-2011 07:29 PM
crankcase breather tube and filter dlh ATV Repair and Maintenance 0 08-13-2011 09:56 AM
oil in airbox from crankcase breather tube mojo ATV Repair and Maintenance 2 05-03-2011 05:03 AM
Crank breather hose filter yzryder125 Polaris Predator 0 08-13-2010 10:06 AM
