Mikuni jet kit from hpd
Has anyone done a carb jet kit from HPD?
The direction state Remove carb slide cover, spring and slide with needle. Turn the slide over and you will see three holes in the bottom of the slide.
This is the problem the slide only has two holes in the bottom. On in the middle and one on the side. Has anyone else ran into this?
