  #11 (permalink)
Old 02-08-2012, 07:41 PM
buddy_1's Avatar
Member #15674
I am by no means an expert on clutch adjustments but I'll PM you a link to a service manual for a simular model so you can check it out. Look at pages 6.19, 6.20 & 6.21 you may have to play with it a little to achieve your desired results. While you have it opened up check your helix and buttons for wear. They can cause power loss also. Buddy
1999 Sport 400 2x4
Complete rebuild w/Wiseco piston by Todd Kerby
Comet clutch
Swamplites front & rear
03 Predator Rear Hubs
ITP Pro Baja Wheels (4x156 front & rear)
DG Front Bumper
Fuj Rear Grab Bars
  #12 (permalink)
Old 02-10-2012, 11:28 AM
mechanic's Avatar
Member #18960
I figured it out! I took apart the driven clutch and the buttons were so worn down that they were cracked. Everything else looks perfect besides a little grinding of metal because the buttons were so worn. Hopefully that should fix my problem. The spring was in the 1-2 spots.
  #13 (permalink)
Old 02-10-2012, 12:13 PM
buddy_1's Avatar
Member #15674
Check you helix good. Mine were worn like yours and had damaged the helix. Buddy
1999 Sport 400 2x4
Comet clutch
DG Front Bumper
Fuj Rear Grab Bars
  #14 (permalink)
Old 02-10-2012, 01:48 PM
mechanic's Avatar
Member #18960
I think that my helix is good. Then again I have never seen a new one. I will take a picture of it later and post it up.
best primery spring for pulling whillies on scrambler
bst color clutch springs for scrambler 500
clutch buttons polaris
comet clutch for my scrambler
how much a 01 polaris scrambler 500 2x4 weights
how much is a clutch belt for a polaris scrambler
polaris 400 sport clutch buttons
polaris 500 scrambler clutch adjustment
polaris atv fourms todd kerby
polaris scrambler 500 clutch button
polaris scrambler 500 pictures of disassembled
polaris scrambler clutch adjustment
polaris scrambler clutch button
polaris scrambler comet clutch
polaris scrambler has now power
polaris scrambler stock primary spring
polaris sxrambler best springs clutch
scrambler secondary clutch setting
setting scrambler 500 clutch alignment
what color clutch spring on a 1999 polaris scrambler 500
