Any installation tips on steering bearing or rear axle bearings? - Polaris ATV Forum
Old 03-11-2012, 10:30 AM
Kevin108's Avatar
Member #23605
Went out to a buddy's farm yesterday for a little shake down run and some trail maintenance. He and his brother are how I was introduced me to riding. That was back in 2000 or so. Somewhere around 08, he sold his Scrambler and went to a lifted golf cart for getting around the property. A couple weeks ago, he bought an 03 Scrambler off Craigslist. It's still at the dealer getting refreshed but yesterday me and my girl went out with our machines to get us down the trails we were working on.
I rolled mine off the trailer, fired it up and heard a grinding noise I hadn't heard when putting around my yard. I looked and the previously tightened chain, even with the HPD tensioner, was slack. Looked further and there was black grease oozing between the rear housing and chain. Damn!
I priced parts locally but in total I saved something like $40 ordering online. Not all of the parts were for steering or the rear axle. The fuel filter I just wanted to have on hand. The grommet keeps the strut from rubbing through the front fender. The single bearing is for the steering post. I may not have needed new lip seals but for the price, I felt better just ordering them along with everything else so I don't have to stop to get some with everything almost put back together.
Code:
2530009 Fuel filter     $ 2
3514352 Bearing         $16
7052028 Grommet         $ 3
5410889 O-Rings         $ 2
3610070 Lip Seals       $12
3554518 Bearings        $26
3554517 Races           $18
I have a copy of the FSM so I have torque specs and general info. I've referenced the Polaris parts fiche plenty of times for exploded views of how things go together. I've done wheel bearings a number of times on my 87 Chevy and the ATV rear axle stuff looks to be similar. I've had the rear swing arm off before to do bushings and replace the sprockets but I've never had the rear axle out. Any tips you might have for replacing either of these bushings, please share.
2005 Scrambler 500
2009 Trailboss 330
Old 03-11-2012, 09:29 PM
cpd159's Avatar
Member #20997
It's pretty straight forward. Only issue I can think of is the axler nuts dont like to come off. I've had to cut them off or more than once. If you have a torch you may be able to get it hot and it may break loose. I always pick up a extra axle nut when I replace axle bearings. Good Luck
Old 03-14-2012, 06:10 AM
Kevin108's Avatar
Member #23605
My axle nuts look like brand new still. Haven't gotten to them yet though. The locking collar was giving me a fit so I stopped for the night. This morning I hosed it down with PB Blaster...and rinsed the mud out of the gap in the snap ring that I didn't notice yesterday. With the snap ring off, I'm probably good to go.
2005 Scrambler 500
2009 Trailboss 330
Old 03-14-2012, 06:41 PM
scat6's Avatar
Member #22929
Another thing to remember is that the rear axle looks like both sides are the same legnth but they're not. If you put it in the wrong way, opposite of how you took it, out it will be sticking out more to the left I belive. Had that happen to me with my 01 scrambler, put it in wrong and it was off to the left enough to notice it right away after I put the tires back on.
2004.5 700EFI Sporty
26x10x12 Dirt Devil XT fronts
26x12x12 Dirt Devil XT rears
custom rear bumper
2500lb warn winch
K&N air filter
Highlifter HD front springs
60" cycle country plow
Old 03-14-2012, 07:46 PM
Kevin108's Avatar
Member #23605
That's a good one! I've still got some hardware on the right side of it so I'll make note of which end is which before I disassemble and clean everything.
Also @cpd the axle nuts came off like the thing was brand new. On each side of the hub, I drove 1 bolt out of the little keeper for access then used my giant channel locks to loosen then nut.
2005 Scrambler 500
2009 Trailboss 330
Old 03-16-2012, 01:35 AM
cpd159's Avatar
Member #20997
I'm jealous!!! I have never had them come off like that unless I had already replaced them. I also should have told you I usually only taked the right side off and slide everything out the left. Looks like you got it covered though. Nice work
Old 03-16-2012, 04:42 AM
Kevin108's Avatar
Member #23605
I've had the swingarm off once to do bushings but I've never had any of the axle stuff off.
My new stuff shipped out yesterday and I got the old stuff all cleaned up.
I think there's going to be a couple of o-rings I need but I can probably grab them at the hydraulics shop down the street.
2005 Scrambler 500
2009 Trailboss 330
Old 03-22-2012, 02:06 PM
factionfx's Avatar
Member #20681
Please keep us up to date on this. I just ordered the parts to do the bearings in my 2006 Trailblazer.
How hard was it to get the old bearings out? And what did you use to get the old bearings out?
Thanks!
Old 03-22-2012, 03:21 PM
Kevin108's Avatar
Member #23605
lol the bearings came out in the grease. It was a spectacular failure. I took a shop rag and began twisting it into the greasy housing. Not that this is a common tool, but what I ended up using was a steel post stuck in the ground. I forced it through the housing, pushing out the greasy rag with the rollers stuck all in the grease. I then used the lip of the post to tap the races out of the housing. It was weird but I didn't have a long enough punch so I made do.
2005 Scrambler 500
2009 Trailboss 330
Old 03-22-2012, 05:05 PM
factionfx's Avatar
Member #20681
That is funny, because I actually thought of doing the same thing. I was actually going to use a wood dowell rod or equivalent to get the old races out.
I am interested to see how the bearings install.
I am planning on putting in a HPD steering post bearing as well. (this would be in my 2000 325 model.
PS, if you happen to be installing the tie rod ends as well, i found them the cheapest on ebay. search "<part number> ALL FOUR"... these are the ones i got. eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Good luck to you!
2012 Sportsman 500, Red.
1997 polaris sport 400 rear axle carrier bearings replacement
2007 polaris scrambler rear axle wont get tight
2008 polaris predator 50 is steering suppose to be a little loose
2008 polaris scrambler rear axle snap ring
chain ware gard 250 trail blazer how to install
how to remove rear axle polaris scrambler 500
how to replace rear axle 2000 500 polaris scrambler
polaris scrambler 500 axle bearings removal
polaris scrambler 500 axle carrier o rings
polaris scrambler 500 rear axle bearings
what size are the jam nuts on a polaris trail boss rear axle
Has anyone replaced rear axle bearings on a TB 330? sinful ATV Repair and Maintenance 16 04-24-2012 01:53 PM
rear axle bearings mudthug_814 ATV Repair and Maintenance 2 02-05-2012 12:12 PM
rear axle bearing issues. Dylan Polaris Predator 6 07-22-2011 09:33 AM
rear axle bearings davidstoncold Polaris Predator 0 07-03-2011 10:33 AM
rear axle bearings and seals??? waldosmiss ATV Repair and Maintenance 2 01-11-2011 09:18 AM
