02-24-2010, 07:00 PM
Member #2441
Can bigger tires go on the scrambler
Just wondering if you can actually put bigger tires on because of the already different front to rear tire sizes????No sure if it will throw it out of whack?
2009 Sportsman XP 850 W/30" ZILLA'S, Team industries 14% gear reduction kit & high altitude clutch kit,3.5 degree advance key,heated grips,superwinch terra 4500,.
2011 RZR w/28" Zilla's, superatv springs, seatbelts and bunch of goodies.
2002 33' Tahoe toy hauler
2008 F350 FX4 crew cab diesel,spartan tuned,S&B,4" back.
02-25-2010, 04:31 AM
Member #3313
you can run bigger tires on the scrambler, but the front will have to be 1 inch taller to keep the gearing right
02-25-2010, 01:13 PM
Member #3177
You can bigger tires on anything!!!
07 Polaris Predator 500
Yoshimura RS3 slip-on
ITP Holeshot HDs
Powermadd handguards
Shockwears shock covers
PRM radiator scoops
Amsoil oil w/ K&N filter
Engine Ice coolant
ODI Rogue Grips
02-28-2010, 05:29 PM
Member #3215
Would you have to worry about doing anything to the clutch if you were to go 1 or 2 inches taller on the tires respective to their different sizes... say +2" to each?
I picked up an 08 last fall and I love it, just considering my options and want to make sure I don't shoot myself in the foot, haha. I like riding trails and playing in the mud and dont want to have to worry about wearing on the belt too badly, I know these things are geared pretty high to start with.
03-03-2010, 05:14 AM
Member #2944
I am thinking on bigger tires as well.
Lots of mud out there with all the snow melt. Along with the mud, lots of ruts.
Last night, I had my skid plate getting hung up numerous times.
I see a vendor on Fee-bay selling a tire/wheel combo with 25x10x12 rears and 26x9x12 fronts.
Hopefully, someone has that size on their Scrambler and can comment on overall performance. Any rubbing? Mods needed?
With the gearing already quite high, maybe dropping a tooth on the fron sprocket would help.
Also, looking for comments on type of tire. I am up in the air on either the ITP Mud Lite or the TSL Swamp lite.
Riding is mainly aggressive trail. Although this time of year it is more of aggressive mud!
03-03-2010, 02:40 PM
Member #3177
I had the ITP Mud Lites on my Eiger, and loved them. If I get a UTE again, that will be my first purchase
ITP Holeshot HDs
PRM radiator scoops
Engine Ice coolant
ODI Rogue Grips
03-06-2010, 03:23 AM
Member #2944
New tires are needed soon.
Went out last night and found some nasty mud - good thing for a winch.
Blew a belt though.
I never hear bad things about Mud-Lites - that will most likely be my choice.
Now just a matter of deciding on larger tires. I hope some people that have gone bigger can weigh in.
The only concern is the gearing. Will it dog it out on the low end? Smoke belts?
It dawned on me after some thought that I can't change the sprockets due to the shaft drive on front.
03-06-2010, 05:31 AM
Member #3177
Blew a belt though.
My Eiger came stock with 25" tires, I went to a 26" tire and felt no lack of power overall. I believe however I would not of wanted to go any bigger. I did later change the clutch to the EPI heavy duty set, and I have tons and tons of lowend.
ITP Holeshot HDs
PRM radiator scoops
Engine Ice coolant
ODI Rogue Grips
04-14-2010, 09:38 AM
Member #4266
so if i wanted to run 26 inch outlaws i couldnt just run 26's i would have to go an inch bigger on the front? or could i just run it like that?
04-14-2010, 06:27 PM
Member #2441
From what I understand the front should be 1 inch taller. But I think there would be a limit to the tire difference. Stock, the front to rear ratio is .95 and going to a 25/26 combo yields a .96 ratio and a 26/27 combo yields a .96 ratio also. I would think that the drive line should accept that little bit of mismatch..
automotive tires that fit polaris scrambler, best tire for polaris scrambler, best tires for polaris scrambler, biggest tires on a polaris scrambler, can i put bigger tires on my atv, can you put bigger tires on a polaris scambler, holeshots on polaris scrambler forum, how big of tires can i fit on a polaris scrambler, how to fit bigger tires on a polaria scrambler, polaris scrambler big tires, polaris scrambler big wheel kit, polaris scrambler mud tires, polaris scrambler tire size, polaris scrambler tires, polaris scrambler wheels and tires, what are the biggest tires for a 2001 polaris scrambler, what are the biggest tires to put on a 96 polaris sport 400, what is the tallest tire for polaris scrambler, what size of tires for 04 polaris scrambler, wheel and tire for polaris scrambler
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
2 stoke and bigger tires
88TB250 |
ATV General Discussion |
4 |
04-05-2010 07:10 AM |
bigger tires
n2mudn |
ATV New Members |
8 |
01-27-2010 04:55 AM |
Rim and tires
chopper89 |
ATV Parts for Sale |
2 |
12-17-2009 06:39 PM |
What tires?
Crazyhorse |
ATV Wheels & Tires |
7 |
12-13-2009 09:40 AM |
Bigger Tires
Jamieg |
1 |
10-01-2009 05:32 PM |
