04 Scrambler no start - Polaris ATV Forum
post #1 of 5 (permalink) Old 01-08-2013, 04:35 PM Thread Starter
Ramit32's Avatar
Hey guys im kind of new to the forum. I have an 04 scrambler 500 H.O that wont start. Has a new fuel pump, has good spark, good battery, just cleaned out the carb, which was very gummed up. It cranks over fine but doesnt even chug or try to start. It was running before i cleaned out the carb, just not extremely well.
2014 Sportsman 550 XP ESP
Magnetic Metallic
Ramit32 is offline
post #2 of 5 (permalink) Old 01-09-2013, 02:41 AM
Bruce! is offline
post #3 of 5 (permalink) Old 01-09-2013, 07:55 AM
mechanic's Avatar
Try using a little starting fluid sprayed right into the air box. Crank it over and if it turns over by its self, or sounds like it's firing. If it does then it's still a carb problem
mechanic is offline
post #4 of 5 (permalink) Old 01-27-2013, 06:31 PM
Palvader's Avatar
Send a message via Skype™ to Palvader
I agree with mechanic, it's an easy check solution that requires no tools. I had the some problem, it would run only on starter fluid, and then I checked the gas tank... very low. I filled her up, squirted that starter fluid, and a few backfires later she was purring like a [loud] Honda!
Peter Lindblom
__________________________
2002 Polaris Scrambler 500 2x4
  • Special Edition model [A02BA50AB]
  • Light bar on front bumper
  • Turn signals
  • Rear skidplate
  • Kolpin handguards [with mirrors]
  • Gas cap fuel gauge
Romans 1:16 "For I am not ashamed of the Gospel of Christ..."
Palvader is offline
post #5 of 5 (permalink) Old 02-01-2013, 01:29 PM
Maxxed103's Avatar
had same problem with my 500 if it sat for a while its probably a stuck float valve and/or clogged jet.
Maxxed103 is offline
99 scrambler 400 no spark..no start nuhuskers ATV Repair and Maintenance 9 06-11-2012 10:20 AM
scrambler 500 will not start with starter abeitner ATV General Discussion 5 05-11-2012 04:50 AM
wont start scrambler 50 chriso ATV Repair and Maintenance 2 02-13-2011 06:58 AM
500 Scrambler won't start jscantland ATV Repair and Maintenance 2 12-17-2010 11:26 AM
1999 Scrambler 400 4x4 how to start michaelbell85 Polaris Scrambler 3 07-04-2010 07:52 AM
