Scrambler 500 electric start problems - Polaris ATV Forum
post #1 of 14 (permalink) Old 03-29-2013, 01:51 PM Thread Starter
LoneKiller37's Avatar
I just got a 2001 scrambler 500 2x4 it ran and started great when i got it but now it has a starting problem. When i go to start it with the electric start all i get is just one click coming from the battery area every time i press the button. lights and everything else works but it just doesnt turn over. after awahile of running i can start it with the electric start but the next day ill go to start it but i just get that clicking noise. What should i look into first?
LoneKiller37 is offline
post #2 of 14 (permalink) Old 03-29-2013, 02:18 PM
Bruce! is offline
post #3 of 14 (permalink) Old 03-29-2013, 05:42 PM
Battery is bad or not charging, should have 12,3 or more volts shut off and 13.5-14.5 when revved up a little, check with multi meter at battery.
Russ C is offline
post #4 of 14 (permalink) Old 03-30-2013, 07:50 AM Thread Starter
I put a new battery in it yesterday still had to pull start it (didnt charge it before putting it in) and i ran it hard for a good hour. I tested the battery when it was running and it held a constant 14 volts so its charging and it was able to start after the ride fine. I will try starting it later today and see if the battery was all it needed. Thanks for the info.
post #5 of 14 (permalink) Old 03-30-2013, 03:23 PM
3 Polaris Atvs's Avatar
Should always charge new battery before use. Clean all your connections on the solenoid and starter connection.
1998 Scrambler 500 HO 4x4
1995 Scrambler 400 4x4
2000 Trailblazer 250 2x4
Sportsman 90 (for my Granddaughter)
1998 Sportsman 500 4x4
3 Polaris Atvs is offline
post #6 of 14 (permalink) Old 03-30-2013, 04:48 PM Thread Starter
yea i know but Ive always gotten away without charging them and i dont have the right charger, the one i have the lowest itll go is 2 amps. The new battery took care of the problem anyways glad it wasnt my starter or solenoid.
post #7 of 14 (permalink) Old 04-07-2013, 01:40 AM
FeltonVillanueva's Avatar
I will be driving the Chevy 2500 HD crew with Texas plates. And the matching Orange Madness Edition XPs. My brother will have his Walker Evans Edition RZR 4 seater.
DVD series deals, discounts, and special price for DVD Sales Online to help you save money!
FeltonVillanueva is offline
post #8 of 14 (permalink) Old 05-29-2013, 04:44 PM Thread Starter
Well it seems like its more than the battery now. The new battery only lasted a few months. It was working fine one day but the next mourning i went to go start it and it was completely dead. I went and got a new battery and PROPERLY CHARGED IT like it tells you and still having the same problems. I went through all the points and cleaned them and even tried the battery in other machines and it works but every time i go to start it, it either slowly cranks then stop or not even turn. opened up the side of the motor and cleaned up the magneto since it was rusted up and gave the starter a couple of taps. It would crank then stop and when it did crank its loud and has a grinding sound in it. Before i go and buy a new one, i wanted to see if theres anything else i should look at? It feels like its drawing way more power than it suppose to when it cranks and kills the battery faster.
post #9 of 14 (permalink) Old 05-29-2013, 08:15 PM
Sounds like it needs a new starter I get them from D-B electric on e-bay, had good luck with them.
Russ C is offline
post #10 of 14 (permalink) Old 05-30-2013, 03:44 AM
RVS Performance's Avatar
X2 on starter
RVS Performance is offline
2005 Sportsman 90 Electric Start problems derezes Polaris Sportsman 3 02-04-2013 12:58 PM
2001 scrambler electric start does not work danb7869 ATV Repair and Maintenance 7 01-13-2013 03:34 PM
2001 scrambler 500 4x4 no electric start or 4 wheel drive bigal87vert ATV Repair and Maintenance 2 08-15-2012 06:26 PM
electric start problem scrambler 2000 xkpierce12 ATV Repair and Maintenance 6 08-10-2012 06:02 PM
Electric Start Problems PatDMania ATV Repair and Maintenance 9 12-20-2010 07:51 AM
