Old 05-03-2010, 04:55 PM
409scrambler4x4's Avatar
Member #4266
Whats going on?
lately my scrambler has been acting up i can ride for about ten minutes then it will start to sputter and black smoke then it will just die i have no clue what to do. i also have gas leaking out of the bottom of my carb if anyone can help please let me know
Old 05-03-2010, 06:01 PM
mcgrath's Avatar
Member #2465
Sounds like a carb problem. Fuel coming from carb is usually caused by a leaky needle and seat or a stuck float. I would first take your carb apart and clean it. If it appears fairly clean I would also change the needle and seat. Start here and see what you find.
Old 05-03-2010, 06:29 PM
Member #4266
alright cuz its been leaking gas for a while and it just started doin all the other stuff
Old 05-05-2010, 05:54 PM
Member #4266
i took everything apart and cleaned the carb but the reason its dying is because the carb is getting to much fuel, the only thing now is where do i go from here do i need to look at something else or what?
Old 05-05-2010, 06:12 PM
3 Polaris Atvs's Avatar
Member #1102
You might need to get a new needle and seat or you float is stuck or set wrong. Gas running out of carb is bad.
1998 Scrambler 500 HO 4x4
1995 Scrambler 400 4x4
2000 Trailblazer 250 2x4
Sportsman 90
1998 Sportsman 500 4x4
Old 05-07-2010, 07:24 PM
Member #4266
alright so i didnt have to replace the seat or the needle, all i had to do was take the old o ring off the seat and replace it with a new one so i went from looking to spend 40 bucks to 7 and all i did was get an o ring assortment at a local parts store
Old 05-11-2010, 05:42 PM
mcgrath's Avatar
Member #2465
Just go to your local dealer and tell him you need a new needle and seat. Its just a needle and a jet. Its about $12, just take out the pin that holds the float plate out and replace. Very easy fix... this is your problem if your floats are set properly. This is a very comon problem in every engine with a carb. Dont screw around with O rings. Its just a waste of time and will drive you nuts.
1995 polaris 300 2x4 leaks gas out of carb when running
1995 polaris scrambler carburetor
1995 polaris scrambler seat
1998 polaris scramber gas leaking out bottom of carb
1998 polaris scrambler seat
1998 polaris trailblazer neddle and seat
98 polaris 300 leaking from top of carb
carburetor leaking on 1998 polaris 2x4 300
how to adjust floats on a carb for a scrambler 400
how to change needles and seats on a polaris atv
how to fix a leaking needle and seat on a 250 trailblazer
installing a needle and seat on a 03 polaris scrambler 500
polaris needle and seat
polaris needle and seat oring
polaris needle and seat replacement
polaris needle seat
polaris scrambler 400 needle and seat
polaris scrambler 400 seat roblem
polaris trailblazer seat and needle
will leaking needle and seat hurt engine in polaris atv
whats up from southern va.! bug man ATV New Members 7 02-26-2010 06:33 PM
whats up from southern va.! bug man ATV New Members 3 02-25-2010 01:35 PM
Whats up with the maninblackk atvjunkie821 ATV General Discussion 7 01-31-2010 05:16 AM
whats up from iowa!!!! rRandel ATV New Members 2 01-20-2010 08:08 AM
Whats Up From Auburn AL odie22 ATV New Members 1 12-27-2009 07:34 AM
