99 400 scrabmbler output shaft
ok guys who know for sure, I'm new here to these fourms, I have a 99 scrambler 400 I let my brother drive and go figure he broke it..
First off I was look to see what part it is for sure, looks to be called the out put shaft, the front gear on the chain for the rear wheels sheared off, the gear is fin but the shaft it mounts to is not, it looks like someone cut through it with a nice saw as it is perfectly smooth, just not attached anymore.
secondly he rode it back using the front wheels in 4wd and then as he was putting it in the shop the front right hub snapped and now no drive
just want a verification of what i need for parts mostly the rear,, from what it looks like in the parts guide its under the section of gear case, part 46..
