07-22-2010, 05:07 PM
Member #5941
changing drive belt,worth changing springs?
since im replacing some original parts i added a drive belt tl the list.is there any benefit to upgrading the clutch springs while its off?if so which ones?there are so many choices i dont know were to start.some of the pipes ive found list a clutch upgrade.does that mean whole clutch or just springs?
07-22-2010, 05:22 PM
Member #5629
If the bike is stock then just change the belt. If your using aftermarket parts and large tires then you should put a clutch kit in when you do the belt. My $.02
Con
07-22-2010, 05:54 PM
Member #5941
tire size is stock but a pipe/reed are on there way here.
07-22-2010, 06:24 PM
Member #5629
You looking for speed or towing/carrying/plowing?
Con
07-22-2010, 06:43 PM
Member #5941
speed.the only thing ii really miss riding the 400 is the off the line snap.HPD states you need a clutch kit with their pipe.i just want to doit right once.
07-22-2010, 07:12 PM
Member #5629
Then I think you should contact any of the manufacturers and choose the one that you think will suit your needs.
Con
07-24-2010, 09:32 PM
Member #5941
i just ordered the ritter stage 1 kit with a couple extras.so ill def be changing clutch parts and getting a new belt.who/what and were could i get a really good belt.ive found some polariskevlar belts on ebay.
500 sportsman clutch spring, change clutch polaris sportsman, change drive belt on 400 sportsman polaris, how do i change the drive belt on my polaris 700 sportsman?, how long is the drive belt on a 2007 polaris scrambler 500, how to change a belt on polaris sportsman 400, how to change a drive belt on a polaris sportsman 400, how to change drivebelt on 1997 polaris 800 atv, how to change the clutch belt on a 2007 polaris scrambler?, inspection of a atv drive belt, polaris drive belt springs, polaris scrambler 500 belt change, polaris scrambler 500 belt check, polaris scrambler 500 drive belt, replacing polaris sportsman starter drive, scrambler 400 clutch spring changes, viper winch polaris scrambler, what clutch spring to change on scrambler 500, what is the benefit of changing a drive belt, when to replace atv drive belt scrambler
