07-15-2009, 08:31 AM
Member #881
2002 scrambler 50cc throttle problems
I bought this for my kids and so far its been a pain in the butt.
as soon as you hit the throttle (no matter how far the stop screw is in ) it pretty much goes full speed. I can't figure it out? it has to be electrical cause i unplugged some of the wires going to a box and it would still run just no throttle response. It's just so hard to teach a kid to ride when the quad only goes one speed which is to fast. any help would greatly be appreciated.
thanks in advance.
07-15-2009, 11:01 AM
Member #752
Could be a problem with the CDI if thats what you unplugged but I wouldnt think it would run with that not hooked up. What did you unplug? Check to see if the jumper is installed across the two terminals of the CDI box. Thats what keeps the speed down under 10 MPH. Iy was missing from ours when I bought it. If its taken off the it will go about 15 MPH. The CDI should be under the front plastics just under the handlebars on the left side opposite the key. I have a 2003 for my son and thats where it is on ours.
07-15-2009, 11:27 AM
And welcome to the board!
07-17-2009, 07:52 AM
Member #881
does your go straight to top speed with very little throttle? ours does. no matter if your pushing it 1/10 or full throttle it goes the same speed. thanks in advance.
07-20-2009, 08:55 AM
Member #881
i hate this quad. i should have bought a honda or kawasaki.
2000 polaris scrambler 50 troubleshoot, 2002 polaris 50 scrambler, 2002 polaris 50cc scrambler, 2002 polaris scrambler 50, 2002 polaris scrambler 50 top speed, 2002 polaris scrambler 50cc, 50 cc polaris scrambker cdi box, 50cc polaris scrambler cdi box, 50cc troubleshooting, polaris 50 scrambler problems, polaris 50cc scrambler, polaris scrambler 50 cdi, polaris scrambler 50 cdi box, polaris scrambler 50 problems, polaris scrambler 50 safety switch problems, polaris scrambler 50 speed, polaris scrambler 50 top speed, polaris scrambler 50 troubleshooting, polaris scrambler 50cc, polaris scrambler ignition problem
