500 Scrambler ( No Spark ) - Polaris ATV Forum
Old 10-25-2010, 06:13 AM
aneville's Avatar
Member #8508
Angry 500 Scrambler ( No Spark )
I have a 1999 500 Scrambler 4X4. Bike had been setting. Started it. It was running ruff. Back Firing would not Idle. Pulled Carb. Had it gone thru. Put it back on. Started it. Ran good but Float stuck and Fuel coming out Float Over Flow. Pull Carb back off adjusted Float tried to start it. No Start. Put New Spark Plug in. No Spark No Fire to Plug. Has new Battery. Lights work.
Any Suggestions?
Old 10-25-2010, 11:18 AM
mechanike's Avatar
Member #5749
make sure you have 1/8" play in the thumb throttle,no more no less+there are 2 off switches one on the bars +the key,,,,,,,,,,,,,,
Old 10-25-2010, 12:05 PM
aneville's Avatar
Member #8508
Ok. Thanks Mechanike a lot for the info soon as I get home I will check the Thumb Throttle Play. As it is it turns over and I can hold the Plug in my had and get nothing. What about the Throttle Play effects it?
Old 10-25-2010, 12:27 PM
mechanike's Avatar
Member #5749
it shuts off the spark if the throttle runs away,if you disconnect the blk wire off of the cdi box and it runs then its probably the etc or a bad switch.it might be a differant color wire maybe,,,,,,,,,,
01 scrambler 500 no spark
1999 polaris scrambler 500 no spark
2000 scrambler no spark
500 scrambler 4x4 no spark
500 scrambler no spark
lost fire on a 97 scrambler 500
no spark on polaris 500 scrambler
polaris scrambler float stuck
polaris scrambler no fire
polaris scrambler no spark
1999 Scrambler 500 No spark Costjohj ATV Repair and Maintenance 2 06-21-2011 08:12 PM
2000 scrambler no spark IMscrambled Polaris Scrambler 4 07-30-2010 06:47 PM
No spark Mag 425 Mudking ATV Repair and Maintenance 2 07-15-2010 08:45 AM
Only Has Spark Sometimes itscody ATV Repair and Maintenance 4 07-12-2010 07:20 PM
Scrambler muffler spark arrestor? NCHawk Polaris Scrambler 6 04-09-2010 07:58 AM
