Fuel leaking out of bottom of Carb - Page 3 - Polaris ATV Forum
post #21 of 21 (permalink) Old 02-17-2017, 09:31 AM
Mrterry's Avatar
There is an o ring that holds the float asembly. I have had the o ring fail twice. There is only 2 screws the hold the bowl on. I had to replace the gasket to stop another leak. The whole garage smelled like gas when that was leaking. Get the rebuild kit and change all the o rings and gaskets. This is on a 2011 scrambler. This had been the worst carb from leaking that I have ever had. I also have had a lot of trouble with the battery. When I bought the scrambler the battery was dead at the dealer they replaced the battery but gave me the original too. Even the new battery would be dead if it sat a week. So I switched back to original after charging. Worked fine but a week later it was dead again. So I ended up taking a battery out of my sled and put in it to try another one. It was a larger battery and a gel battery. Problem solved. I know it sounds like there was a draw on the battery but then the problem would has still been there with the gel battery. There is plenty of room in the battery box for a larger battery. Now I just swap the battery back and forth between the scrambler and my mxz 600.
Mrterry is offline
Fuel leaking from little hose at bottom of carb terkenjegi ATV New Members 10 02-09-2011 02:42 PM
hose nipple on bottom of carb fuel bowl gjones1 ATV Repair and Maintenance 2 10-08-2010 04:09 PM
Tape on bottom of Fuel Tank stuck6 ATV Repair and Maintenance 5 09-10-2010 11:13 AM
2006 Sportsman leaking (a few drops) of fuel from bottom of Carb GingerRam Polaris Sportsman 4 03-08-2010 10:03 AM
Fuel leaking terkenjegi ATV Repair and Maintenance 2 02-15-2010 07:41 PM
