Oil Pressure - Polaris ATV Forum
post #1 of 6 (permalink) Old 11-20-2010, 04:56 PM Thread Starter
BlownC6Vette's Avatar
Oil Pressure
Is there any way to test oil flow or pressure when you fire up a motor? I had a Raptor 660 that had a little bolt you would unscrew a little on the side of the head while idleing that would seep oil to check flow to the top end. Does a 2000 scrambler 500 have a place to check that? The only thing I thought of was taking the oil return off the top of the oil tank and put a catch bottle under it to check flow.
Will
Well done is better than well said.
- 04 Yamaha Raptor 660 - Sold
- Y2K Scrambler 500 4x4 - Sold
- 99 Scrambler 500 4x4
- 08 Can am Renegade 800x
BlownC6Vette is offline
post #2 of 6 (permalink) Old 11-20-2010, 05:01 PM
Diesel man 03's Avatar
I've wondered about the oil pressure on my 500HO, sounds like you have a good idea.
Diesel man 03 is offline
post #3 of 6 (permalink) Old 11-23-2010, 08:34 AM Thread Starter
So there is no real way to check oil flow to the top of the head? Just wondering...
post #4 of 6 (permalink) Old 11-23-2010, 09:11 AM
mechanike's Avatar
yes there is,,,,,,,,,,,,,,,,,,,,there is a pipe plug fitting on the frontside/neartop of the head.must be incredibly careful not to strip the little fitting,make sure you clear things outta the way to get a clear shot,push tight against the head while turning,,,,,,,,,,,can strip very easy.might want to carefully heat the head around the plug alittle,,,,,,,,,,,,,,,stay away from the gaskets.
mechanike is offline
post #5 of 6 (permalink) Old 11-23-2010, 04:49 PM Thread Starter
Awesome. I will check it tomorrow. New motor is going in and taking it out for a test drive
post #6 of 6 (permalink) Old 11-23-2010, 05:25 PM
mechanike's Avatar
that plug is only to put a guage ,,,,,if you want to use it for a bleed it is 8-15 psi,,,,might be messy,do you know the bleeding procedure for the 500?its probably on a thread.
Tire pressure opinions nmpolaris ATV Wheels & Tires 14 03-25-2011 01:55 AM
The importance of tire pressure! armycopter Polaris Sportsman 17 05-24-2010 09:51 AM
Tire pressure nmpolaris Polaris Sportsman 5 04-09-2010 05:56 PM
Instruments-Oil Pressure Ozquad Polaris Sportsman 2 01-09-2010 12:32 AM
Question on tire pressure kdsberman ATV New Members 2 12-16-2009 11:37 AM
