Fuel Line Recall - Page 2 - Polaris ATV Forum
post #11 of 36 (permalink) Old 12-30-2016, 10:08 AM Thread Starter
Martlet's Avatar
Originally Posted by Effer View Post
So what's the difference between the recalled 2 up models and the 1 up models? Wouldn't the fuel line setup be the same?
No difference, I assume. The recall states the intake duct can contact the fuel line, causing a leak which poses a fire hazard.
Martlet is offline
post #12 of 36 (permalink) Old 12-31-2016, 04:30 PM
offthetrail's Avatar
I think what he means is that only the 2-up and 6x6 models are recalled, so where is the difference between those and the 1+up models that aren't recalled. If it's fuel line related, the engine are fuel tank are in the same location on all models, correct?
2015 850 SP - front lock and ride, Ricochet front brush guard, Sirius pro series 20" LED light bar, rear lock and ride with backrest, Polaris 3500 lb winch, reverse lights, heated grips, QSC adjustable weight clutch kit, overfenders, jccapri bushing kit, cecco braces front and rear, front HD springs, twin 1.75 rotopax mounts, HD front pinion cover, rhino rear axles, oem rzr front axles, 14" STI HD3 wheels and 28" bearclaw HTR tires.
offthetrail is offline
post #13 of 36 (permalink) Old 01-05-2017, 10:37 AM
ThorsHammer's Avatar
My guess is that there is a difference in the frame. a cross member in a slightly different location maybe. or any number of other small difference. Possibly the engine is in a slightly different location to account for the longer frame and use the same engines/trans.
25" STI Black Diamond ATRs
Pure Polaris hand guards
4" LED on the pod
Tamarack Titan Luxury Lounger
Cabela's Chainsaw mount
Quadworks Stage 1 power kit
  • Dynojet kit
2" rear spring spacers
Towable/equipment
Custom built road drag grader
Future mods
Rear bumper/brush guard
ThorsHammer is offline
post #14 of 36 (permalink) Old 01-08-2017, 04:57 PM
BlueFire570SP's Avatar
Recall
I got the recall letter today for my 2015 570SP Touring. The letter states
"Model year 2014-2016 Sportsman 570 Touring / UTE / X2 models and 2017 Sportsman 570 6X6 models were manufactured with an air box intake snorkel that may come in contact with the fuel rail or fuel line during operation. The resulting contact between the snorkel and the fuel rail or fuel line may cause a fuel leak that may pose at fire hazard".
I have not had time yet to look at my 570 to see the issue. I plan to look at it over the next few days to see if I can see exactly what the letter is talking about. If anyone already has pictures that would be great.
2015 Sportsman 570 SP Touring
Polaris 2500 lb Winch
BlueFire570SP is offline
post #15 of 36 (permalink) Old 01-09-2017, 04:52 AM
chrisgord's Avatar
no pictures but i hve the same bike as you (2016) and my air intake is definitely rubbing, easy to see when you pop off the seat and the intake cover.
chrisgord is offline
post #16 of 36 (permalink) Old 01-09-2017, 05:43 PM
Thanks, I will definitely take a look at it.
post #17 of 36 (permalink) Old 01-11-2017, 03:48 PM Thread Starter
Martlet's Avatar
I pulled it out today. Hold on and I'll go take pictures;
Martlet is offline
post #18 of 36 (permalink) Old 01-11-2017, 03:58 PM Thread Starter
Martlet's Avatar
Ok, so here are the pictures of mine.
First remove the seat.
Then remove the air box.
They said if there is no rub marks then they only need to install a bar to protect it. If there is rubbing, as is visible in on mine, they need to add the bar, then replace the rail and maybe the air box.
2014 570 Sportsman Touring
Winch and Plow
Martlet is offline
post #19 of 36 (permalink) Old 01-11-2017, 05:53 PM
Thanks for the pics!
post #20 of 36 (permalink) Old 01-14-2017, 02:55 PM
Well I checked mine out today. I only had some very minor rubbing on the bottom side of the air box snorkel. Didn't see any effect on the fuel line components. I still will take it in sometime soon to have the dealer do the bracket modification.
Common Carb Issues pfunk76 ATV Repair and Maintenance 113 01-06-2017 08:47 PM
2002 Sportsman Fuel or Carb Issue thisdj1 ATV Repair and Maintenance 28 09-19-2016 06:09 PM
sportsman 500 fuel line scott09 Polaris Sportsman 4 07-27-2016 01:27 PM
2010 500HO fuel starvation issue--help? richrpilot Polaris Sportsman 4 01-13-2016 12:08 PM
2000 Polaris sportsman hand brake lever RvL3RN ATV Brakes & Suspension 7 01-05-2016 10:56 AM
