clutch question - Polaris ATV Forum
Old 01-01-2017, 06:32 AM
buizilla's Avatar
Member #90802
clutch question
my 2015 570SP doesn't engage the clutch until about 2000-2100 rpm, and then it's kinda jumpy and NOT smooth transition
is this normal?
I am on the fence about a spring(s) upgrade, so the answers here will solve that question
thanks in advance
2015 570 SP-EPS
Polaris winch
Mudzilla 28x10
HMF exhaust
Power Commander
Old 01-01-2017, 11:35 AM
Battle_Design's Avatar
Member #90297
You should have a clutch kit for those heavy tires anyways.
Grab a QSC from rvs performance
850 XP
Old 01-01-2017, 01:49 PM
bp405's Avatar
Member #18562
Yeah I think those tires are making your belt slip until they engage at that high rpm.
2011 sportsman 800 efi
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
Old 01-01-2017, 02:54 PM
Uncledaddy's Avatar
Member #55035
Agreed, just like a torque convertor in a car lossening up/slipping more if you install different gears or larger than stock tires
2014 Sportsman 550 named "Chapter 7"
Lots of mods and add ons
Old 01-05-2017, 07:37 PM
SantiMan's Avatar
Member #91801
I have a new 2016 570 and my bro has a 2013 850 xp. His is smooth acceleration and mine is more like you said jumpy.
Recently installed a QSC kit from the official site quadshopcustoms.com
My acceleration is now smooth as butter. It still has high engagement but its not jumpy about it. It really made a huge difference.
Sent from my SM-N920T using Tapatalk
Old 01-06-2017, 05:30 AM
buizilla's Avatar
Member #90802
I just ordered the clutch kit from QSC, I already bought the clutch removal tool, so we'll see how that goes..
now to figure out how the water is getting in the clutch housing...
thanx all
2015 570 SP-EPS
Polaris winch
Mudzilla 28x10
HMF exhaust
Power Commander
Old 01-06-2017, 05:36 AM
SantiMan's Avatar
Member #91801
thanx all
Probably where the hoses hook up to it. When I did my snorkel kit I noticed the factory tightening wasnt much. If its not thay its the rear seal, no issues with my rear seal and I go as deep as the storage lid.
Old 01-09-2017, 06:10 AM
buizilla's Avatar
Member #90802
definately NOT the hose connections, had those apart 3 times already.... when I do the clutch install i'll remove the rear 1/2 cover for a deeper lookysee
thanks all
2015 570 SP-EPS
Polaris winch
Mudzilla 28x10
HMF exhaust
Power Commander
Old 01-09-2017, 06:32 AM
offthetrail's Avatar
Member #59218
thanks all
The rear cover can leak in two spots. Behind the primary there is a rubber seal/cover to the engine held on by a band tie that can leak, and the rear behind the secondary doesn't seal really well at the transmission.
On my buddy's 570, we used some rubber gasket/sealant at the front and used a larger band tie. On the rear, we just used silicone to seal it to the transmission.
2015 850 SP - front lock and ride, Ricochet front brush guard, Sirius pro series 20" LED light bar, rear lock and ride with backrest, Polaris 3500 lb winch, reverse lights, heated grips, QSC adjustable weight clutch kit, overfenders, jccapri bushing kit, cecco braces front and rear, front HD springs, twin 1.75 rotopax mounts, HD front pinion cover, rhino rear axles, oem rzr front axles, 14" STI HD3 wheels and 28" bearclaw HTR tires.
Old 01-09-2017, 06:38 AM
buizilla's Avatar
Member #90802
thanks all
good info to look for, thanks, I might get around to it this coming weekend if the parts arrive.
2015 570 SP-EPS
Polaris winch
Mudzilla 28x10
HMF exhaust
Power Commander
Hilliard clutch question Lastgoodusername ATV Repair and Maintenance 2 12-10-2016 06:58 PM
Clutch Cover Question Ogre33 Polaris Trail Blazer 5 08-24-2016 01:34 PM
Clutch question cooder9282 ATV Repair and Maintenance 11 04-23-2016 12:37 PM
clutch question bmichaelong ATV General Discussion 3 03-08-2016 04:24 PM
2000 sportsman 500 clutch cover part question RvL3RN Polaris Sportsman 10 01-06-2016 11:02 AM
