Just noticed this about the 570, WTH? - Page 3 - Polaris ATV Forum
post #21 of 82 (permalink) Old 01-05-2017, 05:01 PM
Vandal's Avatar
Originally Posted by Liftedpsd View Post
2016 850 only has one rear brake also. The 1000 is the only one with 2 rears
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Wrong The Polaris sportsman Aces all have two rear brakes....all engines included, and in the US they don't come with turf mode
2016 570 RZR EPS Trail with EBS
Sunset Red
F+R windshields
Quadboss roof
Polaris Rear Cargo box
26X9X12 Maxxis Ceros
26X11X12 Maxxis Ceros
ITP SS 212 Machined wheels
UTV Giant V2 doors
Led Cubes
Polaris Low Profile front brushguard
Departed friends
2001 Kawasaki Bayou 300 4x4, a great 3 wheel drive ATV
2013 Sportsman 500 HO another great atv
2015 Polaris Ace 570
Vandal is offline
post #22 of 82 (permalink) Old 01-05-2017, 05:47 PM
jesnic's Avatar
My sportsman 1000 and 850 X2 both have 4 wheel brakes.
1997 Sportsman 500
1999 Sportsman 500
2005 Trail boss 330
2007 Sportsman 800
2011 Sportsman 850 X2
2015 Sportsman 1000XP
jesnic is offline
post #23 of 82 (permalink) Old 01-05-2017, 05:47 PM
Mikeli_77's Avatar
My last ATV was a 2010 Honda rancher at with IRS and EPS and that only had one rear brake also. Your lucky you didn't buy that ATV because when you have to change the brake rotor you have to take the rear drive shaft out because the brake disc is mounted around the rear drive shaft just behind the engine. Atleast this one you only have to take the hub off and pop out the studs to do it.
2011 Sportsman 850 XP w/eps
Polaris 2500lb winch
26" kenda bearclaws
High lifter springs
Ricochet full skid plates & A-Arm guards
ATV guru front & Rear Brush Guards
w/ built with light bars in each.
Cecco Racing front & rear Frame supports.
2010 Honda Rancher AT w/eps (trx420fpa)
High Lifter springs
Moose front and rear bumpers
Aluminum products full skid plates and A-arm guards
Warn 2500lb winch
Mikeli_77 is offline
post #24 of 82 (permalink) Old 01-06-2017, 03:39 AM
Liftedpsd's Avatar
I thought we were talking about sportsmans? I never mentioned the ace. I said the 850 has 1 and the 1000 has 2 rear brakes. Which is 100% true. So explain to me how I am wrong.
Liftedpsd is offline
post #25 of 82 (permalink) Old 01-06-2017, 04:32 AM
jesnic's Avatar
Lifted, you are correct for sportsman single seaters.
1997 Sportsman 500
1999 Sportsman 500
2005 Trail boss 330
2007 Sportsman 800
jesnic is offline
post #26 of 82 (permalink) Old 01-06-2017, 04:47 AM
MNTNBKR's Avatar
Interesting tid-bit. Looks like they changed their marketing schmoo for 2017.
The 2015 and 2016 Sportsman 850 SP specs list "Single Lever 4-Wheel Hydraulic Disc with Hydraulic Rear Foot Brake" while the 2017 Sportsman 850 SP specs list "Single Lever 3-Wheel Hydraulic Disc with Hydraulic Rear Foot Brake"
(edit: appears they made the same change for all the models with the 3-caliper setup.)
I wonder if they got hammered for inaccurate advertising. You have to admit, it is kind of misleading, even if it's true. (edit:The other, more likely possibility is that they're trying to highlight another "enhanced feature" for the higher end models, since the '17 1000 still says "Single Lever 4-Wheel Hydraulic Disc with Hydraulic Rear Foot Brake")
I always thought it was just the XP line that had the 4 caliper setup (could be wrong on that.) My '15 Touring 1000 has 4 calipers.
2016 Can-Am Outlander Max XT 650, Brushed Aluminum
2015 Sportsman Touring XP 1000 Bronze Mist, Uni-Filter, 2" lift, 28" Bearclaw HTR's, Cobra HD front axles, Glacier Pro Plow system
2008 Can-Am Outlander Max XT 400, Red
1987 Manitou 24' Pontoon w/ 25HP Merc, bimini top, & propane grill
2014 Aluma 8112 utility trailer (my 'lil toy hauler)
1990 Honda Fourtrax 300, blue, plow machine (Sold)
1986 Yamaha Moto 4 225 (sold)
MNTNBKR is offline
post #27 of 82 (permalink) Old 01-06-2017, 06:25 PM
Vandal's Avatar
The Ace is a sportsman.....that's why its name is the sportsman Ace. It is listed as an atv not a utv
Sunset Red
F+R windshields
Quadboss roof
UTV Giant V2 doors
Led Cubes
Departed friends
Vandal is offline
post #28 of 82 (permalink) Old 01-06-2017, 06:27 PM
Vandal's Avatar
You are also wrong. The Sportsman Ace has dual rear brakes....and whatever you want to view it as its still a single seater sportsman
Sunset Red
F+R windshields
Quadboss roof
UTV Giant V2 doors
Led Cubes
Departed friends
Vandal is offline
post #29 of 82 (permalink) Old 01-06-2017, 07:36 PM
jesnic's Avatar
On Polaris.com, the Ace is referred to as it's own category. As is the RZR, General, Ranger, sportsman atv, and finally Ace. Nowhere on their webisite is the Ace referred to as a sportsman. The only place I can find the Ace in the same category as a sportsman is on polarispartshouse.com. The first year of the Ace, it was referred to as a sportsman ace atv by Polaris. But I think it somewhere between a utv and an atv. You could be right and I could be wrong. Doesn't really matter as the Ace is a "different" animal in the off road world. I don't believe any of the other manufacturers even make one? Id on't know why the Ace would have 2 rear brakes either, unless it is offered with turf mode.
1997 Sportsman 500
1999 Sportsman 500
2005 Trail boss 330
2007 Sportsman 800
jesnic is offline
post #30 of 82 (permalink) Old 01-07-2017, 03:02 AM
Uncledaddy's Avatar
Didnt read thru the lunicey, anybody mention rear end is locked, so one hrake or two brakes is going to mean zilcth because 1 will lock up the rear end anyhow. Turf mode machines, sure i can see the benefit of 2 brakes when rear end is uncoupled.
Just think of all the 12,000lb monster trucks racing as fast as they can, omg, th only have 2 brakes, how do they stop....how do w stop this madness since alot of heavy equipment will come with 1 central brake...omfg
2014 Sportsman 550 named "Chapter 7"
Lots of mods and add ons
Uncledaddy is offline
570 EPS first ride review Ronin2 Polaris Sportsman 570 3 08-06-2016 03:20 PM
570 vs Arctic Cat XR 550 XT Vaux Polaris Sportsman 570 68 06-11-2016 11:19 PM
My thoughts on the 570 after one year of ownership Danno59 Polaris Sportsman 570 11 04-24-2016 05:35 AM
Considering a used 570, what to look for? Ronin2 Polaris Sportsman 570 40 03-08-2016 05:39 PM
Close Ratio AWD - Difference between my 570 SP vs 570 EPS Guilow Polaris Sportsman 570 20 01-13-2016 02:21 PM
