Just noticed this about the 570, WTH? - Polaris ATV Forum
post #1 of 82 (permalink) Old 01-04-2017, 08:29 AM Thread Starter
SpyderX's Avatar
Only has one rear brake. That's some BS. I'm disliking this ATV more everyday.
SpyderX is offline
post #2 of 82 (permalink) Old 01-04-2017, 08:32 AM
RSMark5's Avatar
Why? The one brake is more than enough to lock the rear tires.
RSMark5 is offline
post #3 of 82 (permalink) Old 01-04-2017, 08:34 AM Thread Starter
SpyderX's Avatar
Fully loaded down with gear going down a steep trail. Every little bit helps. What's strange is there is a bracket for the brake lines. Have you ever noticed it only has one rear brake?
SpyderX is offline
post #4 of 82 (permalink) Old 01-04-2017, 08:37 AM
RSMark5's Avatar
Yeah, I noticed before I bought it. Still bought it. Haven't noticed an issue once. Coming from a honda with drum brakes it stops like a F1 car.
RSMark5 is offline
post #5 of 82 (permalink) Old 01-04-2017, 09:08 AM
SteveC25's Avatar
My 08 800 is the same way with no stopping issues and I'm sure it ways more than your 570, most of the newer large bore Sportsman's are the only ones with double rear brakes.
SteveC25 is offline
post #6 of 82 (permalink) Old 01-04-2017, 10:25 AM
Liftedpsd's Avatar
2016 850 only has one rear brake also. The 1000 is the only one with 2 rears
Sent from my SAMSUNG-SGH-I537 using Tapatalk
Liftedpsd is offline
post #7 of 82 (permalink) Old 01-04-2017, 10:39 AM
one7oh5's Avatar
Replace the pads when need be, and make sure you got brake fluid and you won't have a problem. And you only have to buy 3 pads instead of 4 so savings right there.
one7oh5 is offline
post #8 of 82 (permalink) Old 01-04-2017, 11:52 AM
bp405's Avatar
The machine is engineered for three brakes. There is no need for the forth brake in the rear left. I have probably changed the pads on my machine 4-5 times and the rear pads are always worn the same as the fronts. There are no balance issues with excess of lack of braking from the front or rear. You have to remember the rear is a locked or posi rear end. So there isn't a need to have two sets of rear brakes because one caliper does both wheels.
2011 sportsman 800 efi
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
bp405 is online now
post #9 of 82 (permalink) Old 01-04-2017, 11:54 AM
phil's Avatar
That's funny. It works! Fewer parts to maintain - you should be happy.
3500 lb. Polaris HD Winch
VIPair Windshield
EPI HD Springs, Front & Rear
Cecco Frame Braces
Guru Bumpers, Front & Rear
Rhino Monster, Rear Box
Lowrance BAJA 540 GPS
SuperATV EZSteer 380
Various Mods for Ice-Fishing
phil is offline
post #10 of 82 (permalink) Old 01-04-2017, 12:20 PM
LittleTreeGuy's Avatar
My stepfathers Arctic Cat is the same way. I thought it was odd too, so I started looking at other quads. Not many have dual rear breaks.
LittleTreeGuy is offline
570 EPS first ride review Ronin2 Polaris Sportsman 570 3 08-06-2016 03:20 PM
570 vs Arctic Cat XR 550 XT Vaux Polaris Sportsman 570 68 06-11-2016 11:19 PM
My thoughts on the 570 after one year of ownership Danno59 Polaris Sportsman 570 11 04-24-2016 05:35 AM
Considering a used 570, what to look for? Ronin2 Polaris Sportsman 570 40 03-08-2016 05:39 PM
Close Ratio AWD - Difference between my 570 SP vs 570 EPS Guilow Polaris Sportsman 570 20 01-13-2016 02:21 PM
