Picked up my used/new 570 yesterday. I have a few ???? - Page 2 - Polaris ATV Forum
post #11 of 16 (permalink) Old 01-09-2017, 04:44 AM
MNTNBKR's Avatar
Originally Posted by fonz3482 View Post
I also was going to hook up a battery tender but the batter had a cover on it so I'll have to remove the cover and install the leads with the ez-connector for the battery tender when it's not 9 degrees outside.
As mentioned above, you don't need to go direct to the battery with the battery tender pigtail. There is a terminal block under the front storage area that is convenient and relatively easy to access.
2016 Can-Am Outlander Max XT 650, Brushed Aluminum
2015 Sportsman Touring XP 1000 Bronze Mist, Uni-Filter, 2" lift, 28" Bearclaw HTR's, Cobra HD front axles, Glacier Pro Plow system
2008 Can-Am Outlander Max XT 400, Red
1987 Manitou 24' Pontoon w/ 25HP Merc, bimini top, & propane grill
2014 Aluma 8112 utility trailer (my 'lil toy hauler)
1990 Honda Fourtrax 300, blue, plow machine (Sold)
1986 Yamaha Moto 4 225 (sold)
MNTNBKR is offline
post #12 of 16 (permalink) Old 01-09-2017, 04:50 AM
chrisgord's Avatar
I like the look of bison bumper up front, and kimpex on the rear personally.
chrisgord is offline
post #13 of 16 (permalink) Old 01-09-2017, 09:36 AM Thread Starter
fonz3482's Avatar
Thanks everyone, I'm gonna look for that connection point for my battery tender this week. We are gonna have a warm up here so I can get out in the garage and tinker with the new ride! I was looking at the Guru bumper with the mesh center, open. Its the $219.99 bumper that has no mesh in front of the headlamps or by the winch. My question is will it interfere any with the winch while its in use?? I see they sell a bumper with a plate welded in for the winch fair lead to bolt too. Do I need to add that plate when I buy it or will it be ok without it? Also my polaris winch doesn't seem to have any kind of stopper at the end of the cable. Just the loop and hook. Should there be a rubber stopper there??? Last atv I had with a winch had the stopper on the end of the lead. Should I install something so the hook doesn't get sucked into the rollers for the winch? Sorry for all the questions. I just like to have everything setup right before I ride on need to use it. Thanks!
fonz3482 is offline
post #14 of 16 (permalink) Old 01-09-2017, 10:21 AM
ThorsHammer's Avatar
A hockey puck with a hole drilled through it, or a small Kong dog toy work as a stopper for the winch. and they are cheap. most winches don't come with the stopper.
Personally, I'd add the plate for the fairlead. I hate that my winch is sucked in behind my bumper. and hands down Guru is the way to go.
My list of must haves on a new ATV. in this order. Winch, Tires, Protection. you've got the winch. Tires, and clutch kits are the best bang for your buck performance modifications that can me made to an ATV. And you're looking into protection. I'm on the full skids side of the fence myself. But if you don't want plastic, Making your own Aluminum skids is relatively easy to do and would cost you less than buying the Ricochet skids. PM me if you have any questions about building your own. Can be done with a jig saw, a drill, a rubber mallet, and a vice.
The rest are all creature comforts that are really based on your own personal needs/requirements for the uses your machine will see.
As for things to do about protecting against the failures that people post about. Maintenance and smart riding are the best ways to prevent issues. as far as the heat goes, get it ceramic coated. My local coater would do the header pipe for $70 and the full exhaust for $160. It reduces the heat, and protects the metal from rust, unlike wrapping, which can cause premature rusting.
25" STI Black Diamond ATRs
Pure Polaris hand guards
4" LED on the pod
Tamarack Titan Luxury Lounger
Cabela's Chainsaw mount
Quadworks Stage 1 power kit
  • Dynojet kit
2" rear spring spacers
Towable/equipment
Custom built road drag grader
Future mods
Rear bumper/brush guard
ThorsHammer is offline
post #15 of 16 (permalink) Old 01-09-2017, 10:56 AM
StevieRay's Avatar
Also, all Atv's I ever owned had a lever at the back of the seat to remove the seat. From how I interpreted the manual this one does not?? You just yank up on the rear of the seat and it's held on by clips?? I want to remove the seat because there is an annoying rattle coming from the plastic over the gas tank. I put pressure on the plastics and the rattle quites down. So I'd like to remove the seat to see why ther is a rattle in that area.
I got that same rattle, but it seems to be only when I've pulled it out of the garage and it's sitting on it's incline, ready to plow. Same thing-push down on the plastic and it quits. But it also seems to stop as soon as I take off. Never really investigated it.
You got a smokin deal on that machine.
2015 Sportsman 570
KFI Stealth SE35
50" Denali Plow
StevieRay is offline
post #16 of 16 (permalink) Old 01-09-2017, 03:04 PM
CAPTKEV's Avatar
That noise is most likely the intake snorkel hitting the plastic around the gas tank. Very annoying, my old SP500 had foam around the snorkel to keep it snug. A zip tie will take care of it.
2017 570 SP Hunter
28" Bearclaws
Polaris Glacier 60" Plow
Power Angle
Sander
Wireless Remote Winch
Polaris Winch Stop
CAPTKEV is offline
Anything To Look Out For When Buying A Sportsman 570? Matt_Justice Polaris Sportsman 29 09-02-2016 09:38 AM
570 vs Arctic Cat XR 550 XT Vaux Polaris Sportsman 570 68 06-11-2016 11:19 PM
My thoughts on the 570 after one year of ownership Danno59 Polaris Sportsman 570 11 04-24-2016 05:35 AM
Picked up my new orange sportsman 570 today Cyr_256 ATV General Discussion 20 03-08-2016 09:01 AM
Close Ratio AWD - Difference between my 570 SP vs 570 EPS Guilow Polaris Sportsman 570 20 01-13-2016 02:21 PM
