2014 Sporstman 570 won't start - Polaris ATV Forum
post #1 of 7 (permalink) Old 03-19-2017, 01:29 PM Thread Starter
cb196's Avatar
I was out plowing and I couldn't get my 570 out of gear. The only way it would come out is if I shut it off. I got it in the garage and rebuilt the primary and secondary clutches. Put it all back together and now it won't start. Can't figure it out. I have spark, It did back fire once and it was really loud. It turns over but won't fire up. Any help would be a big help. Thanks, Craig
cb196 is offline
post #2 of 7 (permalink) Old 03-20-2017, 04:53 AM Thread Starter
cb196's Avatar
Does this sound like the flywheel pin or timing issues.
cb196 is offline
post #3 of 7 (permalink) Old 03-20-2017, 05:11 AM
gotgps's Avatar
Sounds like what happened with my 2014 570 Touring. It was a nightmare getting it started. I changed batteries, plugs. Greased all electrical connections. Last thing before taking it to the dealer, I figured I may as well check the ignition..... That was the problem. The plastic around the key was cracked and would only make contact about 20% of the time. It only take 3 screws to check....
gotgps is offline
post #4 of 7 (permalink) Old 03-20-2017, 05:23 AM Thread Starter
cb196's Avatar
I put a new battery in it, I have spark, and gas. I'm going to pull the plug today and put in a new one. Hopefully the plug is the problem. gotgps, thank for the reply.
cb196 is offline
post #5 of 7 (permalink) Old 03-20-2017, 11:10 AM Thread Starter
cb196's Avatar
Well I just put a new NGK plug in it. Before putting the plug in I spayed starter fluid in. Well I turned the key and a really loud bag came out of the muffler. I would get a little puff sound out of the muffler and every now and then a strong compression coming from where the primary clutch is, when this would happen I notice the lights on the speedometer would shut off and turn back on. Also sounds like the steering motor keeps running, you can hear it when the key is on. Still can't figure it out, Hopefully someone out there had the same issues.
cb196 is offline
post #6 of 7 (permalink) Old 03-20-2017, 02:05 PM
ThorsHammer's Avatar
check the ignition. if you're getting a bang out of the exhaust, there is spark, but it's on the exhaust stroke. adjusting/fixing the clutches wouldn't have messed up the timing at all. those components were still all connected together when the clutches were off. This sounds electrical to me.
25" STI Black Diamond ATRs
Pure Polaris hand guards
4" LED on the pod
Tamarack Titan Luxury Lounger
Cabela's Chainsaw mount
Quadworks Stage 1 power kit
  • Dynojet kit
2" rear spring spacers
Towable/equipment
Custom built road drag grader
Future mods
Rear bumper/brush guard
ThorsHammer is offline
post #7 of 7 (permalink) Old 03-20-2017, 05:58 PM Thread Starter
cb196's Avatar
going to check the timing tomorrow.
cb196 is offline
2014 Sportsman 570 Won't Start Chunai Polaris Sportsman 570 7 03-20-2017 05:02 PM
570 Wont start. Valve Adjustment? darius427 ATV Repair and Maintenance 40 10-26-2016 03:44 PM
570 hard to start when cold. the_transporter Polaris Sportsman 570 14 10-03-2016 02:13 PM
Polaris winch direct fit Sporstman Touring 570 SP - PART NUMBER HELP - fitsector Polaris Sportsman 570 3 05-04-2016 06:02 PM
