Front Diff Fill Plug - Polaris ATV Forum
 3Likes
post #1 of 15 (permalink) Old 04-13-2017, 06:20 AM Thread Starter
andwes03's Avatar
I'm about to change all the fluids on my 570 before a weekend getaway to Snow Shoe Rails to Trails next month. I read on here in a few places that you need to remove the bumper and winch mount in order to gain access to the fill plug. I haven actually gone out and looked at mine yet as I'm at work. It is possible to modify the mount either by notching or drilling a hole to prevent this much disassembly in the future or am i thinking to far into it? Like i said i haven't actually gotten out to look at the ATV yet just brainstorming/wondering if anyone has done this
*2015 Sportsman 570*
- Viking front brush guard
- 3 Headlight Mod
- Rear steel Tough Rack
- Kenda Bearclaw HTR's
- 12 inch Light bar up front
- Flush Mount LED Headlights
- LED light pods on Tough Rack for reverse lights
- QSC Clutch Kit
- Heated Hand Grips
- Heated Thumb Throttle
- Billet Aluminum Thumb Throttle
- Polaris Lock and Ride Rear Box
andwes03 is offline
post #2 of 15 (permalink) Old 04-13-2017, 06:36 AM
darius427's Avatar
I am not sure. I did an oil/diff change on my friends last weekend and it really is not that bad. He has the polaris bumper on his, but he does not have a winch. With his, I just removed the grill piece that needs to be removed to install the winch. I was able to get it done through that opening. I have a winch and bumper on mine. I will be changing it in the next couple of weeks. I am hoping to be able to just unbolt the winch and move it out of the way and go through the same opening. It will be a real PITA if the bumper has to be removed each time. Good luck and let us know what you end up doing.
SantiMan likes this.
My up north ride
2016 Sportsman 570SP (Titanium Matte Metallic)
My at home ride
2013 Sportsman 800 (Green)
Wifes
2015 Sportsman 570SP (Sunset Red)
2013 Sportsman 500 (White)SOLD
darius427 is offline
post #3 of 15 (permalink) Old 04-13-2017, 08:57 AM
Old509cc's Avatar
The way the Polaris winch and mount sits in mine it did not look possible to drill out the winch mount to gain access. Some say it's not a big deal but with the plow mount on mine too I don't want to have to pull it all out when I change the fluid, which is more often than most. So I drilled out the plug, tapped it for 1/8 npt and ran a line up to the box to fill. At least this way the vent line can still do it's purpose while I pump the new fluid in.
My ride
1999 Sportsman 509
Rebuilt. R2C air filter. QSC clutch kit in a QSC primary. Block & tank heaters.
All steel grease-able tie rod ends. HPD steering bushing. Custom hub vents.
25" Sedona ripsaws on 12" Badlands. 2" level. Custom shock covers. Oury grips
Backup light. LED low beams. HID 35W high beam. Rev override switch delete.
Alba water temp, VDO volt, oil temp & pressure gauges. Cooling fan light.
Hand and thumb warmers. Borla 14" Pro XS muffler. Custom prop shaft lock collar.
Dad's
2014 Sportsman 570 EPS
2500 Polaris. Polaris hand warmers. Lock & ride windshield. 60" Glacier.
Brothers'
2006 Sportsman 500 HO
Polaris 2500 winch. 24" box. Custom prop shaft lock collar.
2014 RZR S 800
Superwinch Tera 3500. Polaris roof, custom mounts. Pawltector parking brake.
Front & rear bumpers. Custom fire extinguisher mount. Rear diff pinion nut Torqued.
Faithful friends no longer with us
2004.5 Sportsman 500 HO.
2007 Rincon 680
Old509cc is online now
post #4 of 15 (permalink) Old 04-13-2017, 09:03 AM Thread Starter
andwes03's Avatar
Ok, good to know. Guess it was to good to hope for small modification to make things easier haha
- 3 Headlight Mod
- QSC Clutch Kit
- Heated Hand Grips
andwes03 is offline
post #5 of 15 (permalink) Old 04-13-2017, 12:13 PM
bobx2's Avatar
How do you know when it is full? Guess you could just measure out 9 oz and hope none gets spilled.
WilliamBos likes this.
bobx2 is offline
post #6 of 15 (permalink) Old 04-13-2017, 02:01 PM
Old509cc's Avatar
Exactly. I measured out how much it holds and it was really close to 9oz. Now I just use a gear lube bottle to measure out 9 oz and squirt it down my tube.
My ride
1999 Sportsman 509
Dad's
Brothers'
2014 RZR S 800
2007 Rincon 680
post #7 of 15 (permalink) Old 04-17-2017, 03:44 AM Thread Starter
andwes03's Avatar
I changed the fluid over the weekend and came to the conclusion there really isnt any other way besides removing the bumper and grill assembly to gain access. i even went as far as heating up a hex key wrench and bending it to see if i can have a specialty tool for the job with no luck. I wasnt to keen on the idea of putting a hose on the filler or anything as i didnt want to overfill it. Just comes down to removing some stuff to get the job done. Kind of a PITA but at least it shouldnt be all that often it has to be done
bobx2 likes this.
- 3 Headlight Mod
- QSC Clutch Kit
- Heated Hand Grips
andwes03 is offline
post #8 of 15 (permalink) Old 04-17-2017, 06:24 PM
byrd1's Avatar
I have a viper winch mount on mine, I changed my oil the other day before I installed the winch. I noticed this was going to be a issue also. I think next time I might can use a Allen socket with a swivel to remove the plug. I didn't try it, but it looks do able. 1/4 or 3/8 drive.
byrd1 is offline
post #9 of 15 (permalink) Old 04-17-2017, 06:54 PM
WilliamBos's Avatar
Remove grill, unbolt the 4 winch bolts, slide winch out and set it on a block. Remove fill plug, remove drain plug, measure out 265ml and pour it in.
Name:	2011 to Present diff fluid.jpg
Thanks,
Will
2012 Sportsman 400HO - 5,800KM and counting.
25" Traxion Grippers
Warn RT 25, Warn Hawse Fairlead, Synthetic Rope, Glacier III plow, Kolpin Rear Trailbox L&R Mounts.
6" Front LED Lightbar
Polaris HD Front coils
Polaris Hand & Thumb Warmers.
WilliamBos is offline
post #10 of 15 (permalink) Old 04-18-2017, 03:10 AM Thread Starter
andwes03's Avatar
3/8 is out, i tried that with no luck. just not enough room. There might be a small chance with 1/4 but even that i wouldnt bet on. its very tight and its a hard angle. I was very optimistic about being able to do it without removing everything but had to bite my pride and just do it. hopefully you have better luck though
- 3 Headlight Mod
- QSC Clutch Kit
- Heated Hand Grips
andwes03 is offline
Front diff refill plug bigsal1 ATV Repair and Maintenance 5 03-20-2017 03:49 PM
Front Diff - very dirty fluid DOAinNY Polaris Sportsman 570 6 08-23-2016 08:04 PM
fill plug for front diff. bigsal1 Polaris Sportsman 570 11 08-22-2016 05:43 PM
Hub strut compatability sniper4x4 ATV Brakes & Suspension 3 04-05-2016 07:24 AM
