Before the warranty runs out - Polaris ATV Forum
 3Likes
post #1 of 15 (permalink) Old 04-14-2017, 06:27 AM Thread Starter
dennisnielsen's Avatar
Thumbs up Before the warranty runs out
What other issues should I check before my warranty runs out?
Thanking you in advance, Dennis
Woodland just addressed hard shifting and secondary clutch adjustment being a way to correct it.
Another said doing a water intrusion check where the back of the clutch housing mates to the engine.
Other pearls of wisdom anyone?
First ride:My brother's old Baja 500 entry sponsored by Bushmaster body corp. *not 1000 miles years ago....
Tubular frame buggy, Porsche jugs machined to VW block, " Pat Rutledge machinist" a VW bus close ratio transaxle & turning brakes.
My dad bought it for me to learn how to drive @ 10 & I been hooked ever since passing along the adrenaline to offspring for decades.LOL
Current rides:2015 570-a keeper 2016 570 X2-a keeper 2012 550 X2-selling Yamaha Grizzly-selling
Past rides:2008 800HO red Sportsman, sold. 2008 800 HO Sportsman X2 stolen. & pizzed 2009 RZRs, sold.
Too many scooters to mention so lets go with the rare ones I need to kick myself for parting with.
1979 Honda CBX filled with Ontario Motor Speedway parts, Yoshi 6 into one & gummy bear PZ2s on the street.
1979 Kawasaki Z1R-TC only 500 made 10.32 quarter mile stock. $4400. when new in 79.
Used one just sold for way over 100k... hindsight is 20/20
dennisnielsen is offline
post #2 of 15 (permalink) Old 04-14-2017, 09:20 AM
MustBeNice's Avatar
I'd check wheel bearings, ball joints, tie rod ends and suspension bushings.
Doubt they'll do anything for clutch case leaks, but it's worth a try!
Matthew "MustBeNice"
MustBeNice is offline
post #3 of 15 (permalink) Old 04-14-2017, 10:10 AM
ThorsHammer's Avatar
no warranty coverage for the clutch case leaking. it's above the "abuse" line an water above the foot wells is considered abuse in their eyes. But it's worth fixing yourself if you intend to go through water.
if there is something that doesn't seem right, start a warranty claim on it now. if it doesn't equate to anything now, but does in the future, it can some times be claimed under warranty if it had a claim started before warranty was up.
25" STI Black Diamond ATRs
Pure Polaris hand guards
4" LED on the pod
Tamarack Titan Luxury Lounger
Cabela's Chainsaw mount
Quadworks Stage 1 power kit
  • Dynojet kit
2" rear spring spacers
Towable/equipment
Custom built road drag grader
Future mods
Rear bumper/brush guard
ThorsHammer is offline
post #4 of 15 (permalink) Old 04-14-2017, 10:45 AM
darius427's Avatar
This is not necessarily true. Although I still doubt they would cover it under warranty. Mine and a couple others on here were so poorly sealed that they would suck splashed water into the housing from hitting normal small inch deep foot diameter puddles on the trail.
darius427 is offline
post #5 of 15 (permalink) Old 04-15-2017, 03:31 PM Thread Starter
Thanks for the input guys
post #6 of 15 (permalink) Old 04-17-2017, 09:34 AM
water + speed = splash that gets sucked into the clutch intake. Sealing the case won't stop that regardless. the clutch intake on the 570 is almost line of sight from the front left tire. When most people "seal the case" it's for water that leaks in through the joint in the clamshell (bad foam sealer) or through the shaft ports on the back of the clam shell (no seal installed) these really only ingest water when the water level is above the floor boards. and thus constituting as abuse in Polaris's eyes.
coming up with some sort of inner fender, to deflect water from the intake will stop that. I know some people have talked about using Frogskin over the intake to help prevent some of the water ingestion.
4" LED on the pod
  • Dynojet kit
Towable/equipment
Future mods
post #7 of 15 (permalink) Old 04-17-2017, 10:06 AM
darius427's Avatar
I have to believe that you are not totally comprehending what happens when the back cover is not sealed. As I said, the "splash" is what is getting into the clutch case, but it is not through the intake. I ride usually in a large group of people. Many of us ride 570's. We all hit the same puddles going the same speed while going down the trail. If it was simply splash entering through the intake we all would be stopped every 5 minutes emptying the clutch. This however is not the case. Mine may have been magnified by the fact that the zip tie was also missing on the inside, but that was not the entire problem. After I put the zip tie on, I put everything back together without putting any sealant on it, and filled the case through the intake with the hose. It still leaked out the back of the case profusely. If water can get out, water can and will get in. I pulled it back apart, sealed it up and have not had a drop in it since. Oh, and just to let you know, I went riding and hit (at high speed) every puddle on the trail I could find. Had water splashing over the front end on multiple occasions. Also drove through long flooded out sections of trail with water over the floorboards. Guess what...No leaky. So, where your idea of water coming in through the intake is possible and even probable in some cases, it would take a lot of splash back to cause belt slippage and the amount of water I was getting in my case. However, when that lower "seal" is not sealed, it allows any and all splash to be "sucked" in by the vacuum the clutch is creating, which in turn will very quickly cause your housing to fill up and your belt to slip.
jhalpinjr likes this.
My up north ride
2016 Sportsman 570SP (Titanium Matte Metallic)
My at home ride
2013 Sportsman 800 (Green)
Wifes
2015 Sportsman 570SP (Sunset Red)
2013 Sportsman 500 (White)SOLD
post #8 of 15 (permalink) Old 04-17-2017, 01:47 PM
there have been several posts on here of guys complaining of water ingestion caused by riding to fast through puddles on the 570 because of the way the intake for the clutch is set up. while your case is valid, it is not the only situation. It doesn't take that much water to get the clutch to slip. Speaking from experience. I've ingested water into the clutch by going to fast through puddles several times causing the clutch to slip. Never drained more than a table spoon of so of water out of it. as the incoming air goes right to the primary clutch. It's not just the 570 that can have this happen.
Now, in your situation, it would seem that sealing the back of the case was the only real problem solver, but I highly doubt that they would be willing to cover that under warranty, but that would depend on the dealer and how willing they are to work with you/fight for you.
4" LED on the pod
  • Dynojet kit
Towable/equipment
Future mods
post #9 of 15 (permalink) Old 04-17-2017, 04:25 PM
Vandal's Avatar
Red face
[QUOTE=ThorsHammer;1105641]there have been several posts on here of guys complaining of water ingestion caused by riding to fast through puddles on the 570 because of the way the intake for the clutch is set up. while your case is valid, it is not the only situation. It doesn't take that much water to get the clutch to slip. Speaking from experience. I've ingested water into the clutch by going to fast through puddles several times causing the clutch to slip. Never drained more than a table spoon of so of water out of it. as the incoming air goes right to the primary clutch. It's not just the 570 that can have this happen.
Now, in your situation, it would seem that sealing the back of the case was the only real problem solver, but I highly doubt that they would be willing to cover that under warranty, but that would depend on the dealer and how willing they are to work with you/fight for you.[
I didn't know that a Hawkeye could go fast enough to make a splash....LOL Just pulling your chain Thorshammer
2016 570 RZR EPS Trail with EBS and Turf mode
Sunset Red
F+R windshields
Quadboss roof
Polaris Rear Cargo box
26X9X12 Maxxis Ceros
26X11X12 Maxxis Ceros
ITP SS 212 Machined wheels
UTV Giant V2 doors
Led Cubes
Polaris Low Profile front and rear brushguards
Badlands 3500# winch with moto-alliance winch mount
Departed friends
2001 Kawasaki Bayou 300 4x4, a great 3 wheel drive ATV
2013 Sportsman 500 HO another great atv
2015 Polaris Ace 570....Problem free and too much fun
Vandal is offline
post #10 of 15 (permalink) Old 04-17-2017, 04:28 PM Thread Starter
LOL zing
Polaristar Extended Warranty 25% Forum Member Discount fixmytoysCHRIS FixMyToys.com 70 03-03-2017 10:42 AM
Extended Warranty worth it? solomyn ATV Purchasing and Price 16 11-08-2016 10:58 AM
Polaris extended warranty Dylanfreezen81 ATV Performance Modifications 17 08-23-2016 06:17 AM
Different idea for extended warranty coverage DOAinNY Around The Garage 3 11-30-2015 01:24 PM
