Sportsman 570 Battery placement??? - Page 2 - Polaris ATV Forum
post #11 of 29 (permalink) Old 11-26-2013, 06:36 AM
Kme743's Avatar
Originally Posted by creekman View Post
ive inspected my buddies new 570 & rode it LOL, i wouldnt own a new one thats for sure!!!
Just curious, why not?
well for starters the all the plastics seem thinner & flimsy(body, clutch breathers ect..) the mounting points seems thinner(rear stabilizer, front brush guard, motor mounts ect..) & alot of electrical connections seem to unplug way too easy. just my .02 cents i wouldnt own a new sportsman, ill stick with the 2004-2008 models
I will agree, the plastic seems kinda thin and cheesy. As for the other things, this is my first Polaris, so I have nothing to compare it to. I guess only time will tell....
2014 Sportsman 570 - WARN RT30 winch/ KFI mount, Symtec heated grips, STI Black Diamonds, STI HD beadlocks, Acerbis ATV hand guards, Polaris HD Springs, homemade "Lock & Ride" cooler rack, Polaris Lo-pro windshield (winter), more to come....
2012 HD Street Bob
2008 Honda CRF 250R- SOLD
2006 KTM 250 XC-W -SOLD
2002 Suzuki RM 250 -SOLD
2001 Yamaha Warrior -SOLD
1996 Yamaha Blaster -SOLD
1994 Honda XR 100R -SOLD
1976 Yamaha DT 175 - First Bike
Kme743 is offline
post #12 of 29 (permalink) Old 11-26-2013, 06:53 AM
WilliamBos's Avatar
The worst thing about the pre 2011 models is the rad location, not well thought out.
Nothing older than a 2004.5 model, older transmissions were horrible, and the central halliard is much better. And for the price of used, there is no way i would buy used.
Thanks,
Will
2012 Sportsman 400HO - 5,800KM and counting.
25" Traxion Grippers
Warn RT 25, Warn Hawse Fairlead, Synthetic Rope, Glacier III plow, Kolpin Rear Trailbox L&R Mounts.
6" Front LED Lightbar
Polaris HD Front coils
Polaris Hand & Thumb Warmers.
WilliamBos is offline
post #13 of 29 (permalink) Old 11-26-2013, 06:25 PM
creekman's Avatar
Originally Posted by Sportsman570 View Post
Originally Posted by beavis View Post
I signed the papers on my new Sportsman 570 on Saturday and am picking it up tomorrow. When I took a good look at it after they prepped it I noticed where Polaris located the battery. WTF???
I didnt notice this on the sales floor because it was in between 2 other ATV's. It seems really low and close to the front driveshaft.
I may not have bought it if I had seen the location before then. Is anyone else concerned?
Can the battery go under water with no ill effects? I have been worried about this since noticing it, should I be or am I worrying about nothing?
At first I shared your concern but It's not an issue. I plow through swamps, run over all sorts of brush, briers and small trees; the battery has been submerge, all without issues. If it really bothers you, a cover could be fabricated easily. I like being able to clean mine off with my pressure washer.
you do know that washer your wheeler with a pressure washer isnt good on it right?
creekman is offline
post #14 of 29 (permalink) Old 11-26-2013, 06:28 PM
WilliamBos's Avatar
If common sense is used, there is nothing wrong with pressure washing your atv. Keep a safe distance, you will be fine.
Thanks,
Will
post #15 of 29 (permalink) Old 11-26-2013, 07:07 PM
Sportsman570's Avatar
Yep, I recall reading that somewhere. My pressure washer is just a cheap 'O 1800 psi model. The same one I use to wash my F250. I just don't point it at items it could be easily damaged (elect. connections/ engine ). It does a fantastic job of removing the "swamp" off the quad, especially under the fender wells and the tires, wheels etc. If you keep the nozzle 12"-18" away it doesn't hurt anything.
Sportsman570 is offline
post #16 of 29 (permalink) Old 11-27-2013, 05:59 AM
bgirard420's Avatar
Another opinion here, a little dielectric grease on the terminals/connections wouldn't hurt either.
I can tell you that where the battery is located on my 500 doesn't offer much protection against water and mud. As a matter of fact the tires cake it in mud and water. I do agree that submersion might be a concern, but this isn't the first model to put the battery down there.
Make sure you only use sealed batteries on it if you ever replace the OEM one.
Rather be riding, instead I'm using Tapatalk
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
bgirard420 is offline
post #17 of 29 (permalink) Old 11-27-2013, 06:14 AM
WilliamBos's Avatar
Sealed as in non serviceable? And do the sealed ones eliminate the vent tube?
Thanks,
Will
post #18 of 29 (permalink) Old 11-27-2013, 07:01 AM
steve302's Avatar
I agree, the battery location looks like an after thought. Here's to hoping it will be fine.
I had mine in a couple feet of water, iced over so very cold and no issues. but time will tell
steve302 is offline
post #19 of 29 (permalink) Old 11-27-2013, 07:54 AM
hieneken49's Avatar
The plastic is plenty thick. I love mine so far. got it up to 60 last night on the dirt road, rides like a champ. well worth the money, and across frozen famr fields its like a caddy. smoother than my jeep.
hieneken49 is offline
post #20 of 29 (permalink) Old 11-27-2013, 09:05 AM
bgirard420's Avatar
Exactly on both counts.
2010 Polaris 500 HO
Reg. Sticker Placement DrZew ATV Visual & Body Modifications 4 04-27-2012 01:12 PM
License plate placement Muggin ATV Visual & Body Modifications 3 02-18-2011 04:24 PM
ADC electrical wires cut due to poor placement ka-pow Polaris XP 0 07-20-2010 02:15 PM
02 trail boss 325 battery placement? pafree ATV Repair and Maintenance 2 02-17-2010 05:08 AM
2004 Plow Mounting Placement pasty64 Polaris Sportsman 1 09-15-2009 05:21 PM
