Quadboss Weekender on 570 - Page 2 - Polaris ATV Forum
post #11 of 16 (permalink) Old 05-26-2015, 03:20 PM
indyredsporty's Avatar
I spoke to you a while back about how to install the weekender on my sportsman. You gave me some direction on what to do but now i have the mounts and trunk and am not sure what size holes to drill and how to go about putting the anchors through. Do i drill a 1in hole to fit the hole anchor thru up to the plastic washer or a small 5/16" hole and disassemble the anchor and just put the stud thru? Do u have any pics of the inside where the mounts are? Any help would be appreciated. Thanks. I just spent a hefty chunk of change on this and dont want to screw up.
indyredsporty is offline
post #12 of 16 (permalink) Old 05-27-2015, 03:50 PM Thread Starter
dirtyjerzy's Avatar
I drilled a large hole in the bottom of the weekender so that the round rubber portion of the lock n go would fit through the hole. Not sure if it was exactly 1inch, I used a step drill bit and just kept increasing the hoe size one step at a time till the rubber part fit through with the lock n go lever disengaged.
Also after installing I had to adjust the tightness of each lock n go.
____________________
2014 Sportsman 570
Terra 35 Winch
Superatv Front Bumper
Polaris Handguards
Quadboss Weekender
dirtyjerzy is offline
post #13 of 16 (permalink) Old 05-28-2015, 07:10 PM
Swampjunkie's Avatar
I have the same one, it is comfortable for the passenger and it holds a lot of gear. I may have different lock n ride fasteners than you, but I only have 3/8 holes in the weekender where just the pins fit through. The spacers and rubbers stay below the bottom of the weekender unit. 1 inch holes would not work with my lock n ride mounts, mine are from 2013 and I know they have since changed them.
Swampjunkie is offline
post #14 of 16 (permalink) Old 05-29-2015, 06:25 AM
bobx2's Avatar
Those things just look like the perfect opportunity to flip over backwards. An accident just waiting to happen. No thank you.
bobx2 is offline
post #15 of 16 (permalink) Old 05-29-2015, 07:32 AM
furious465's Avatar
I agree, just my stupid opinion but they are ugly also, too much bulk.
2015 sage green Sportsman 570 EPS
Yamaha Banshee based 300ft dirt/sand drag bike
2013 sage green Sportsman 500 ho (sold)
I am a 2 stroke know it all
furious465 is offline
post #16 of 16 (permalink) Old 01-08-2017, 07:18 PM
JackG79's Avatar
Sorry to rehash an old thread, but I have a question about how you installed your "Weekender" Were you able to all 4 "Lock N Ride" plugs inside of the actual storage compartmetn, or did you have to slide it forward and screw two angled brackets to the flat part on the back of the "Weekender" and then drill through those to keep it forward? Ending up with 2 lock N ride plugs in side, and two outside/under the back lip?!?!
2016 Polaris Sportsman 850 SP Metallic
2000 Suzuki Quadrunner LT 500 (*sold*)
2001 Suzuki King Quad 300(*sold*)
2005 Yamaha Grizzly 660 (Blue)(*sold*)
Past ATV's: (Classics)
1984 Honda 185S
1984 Big Red (ATC200ES)
1986 FourTrax 125
1986 Honda ATC 250R
JackG79 is offline
QuadBoss Weekender Trunk Review infernored Polaris XP 7 02-18-2017 12:43 PM
Quadboss belt zoomeroo ATV Repair and Maintenance 1 01-20-2014 12:58 PM
Quadboss? danxrs05 ATV Performance Modifications 0 02-12-2013 06:55 AM
Sportsman 800 Quadboss Weekender mounting edwardt Polaris Sportsman 1 12-25-2012 02:53 PM
Quadboss CDI box baam5774 Polaris Scrambler 0 05-08-2011 05:23 PM
