Hi I bought this machine and January and haven't really had a chance to ride it however my first ride was this weekend and was running fine for the first part of the day and on my way home I started having a bit of a zipping noise by my break right foot , and kind of sounds at the flywheel and when the throttles pushed past half and the motor starts to work or going down the road and I punched the throttle it has a really loud slapping knocking noise and the front of my motor . I took it back to the dealer the clutch is good , the noticed the noise and contacted polaris and was told to leave it and ride it till something breaks ,
I couldn't ride the quad when I first got it cause I got into a snowmobile accident and had to have surgery. And I don't want to blow this brand new machine up and have it lock up on me going down the road or have something blow through and hit me. Me and a friend both bought the same machine same time . His has no problems. When you open it up the knocking is so loud it's kinda scares the hell out of you and everyone I riding around me can hear it loud and clear from there machines . I don't wanna blow up a new machine and don't want me or anyone else to get injured if something happens . Any suggestions would be greatly appreciated. Ontario Canada
Is the 570 a twin cylinder? Has it lost power. If the first two are yes sounds like a bad wrist pin or a broken connecting rod But don't "ride till it breaks" you will have to walk home.
The mechanic was going back and forth with polaris and the mechanic said that polaris has documented that I'm having an issue. And I have extended warranty on the machine. So if anything happen's. It will be fixed. But it is kinda a satiety issue at this time and why should I have a brand new machine with an obvious issue. I don't ride much maybe 300 miles a year, I farm and use it there and a bit in the trails when I get free time. That's why I buy new. A machine will last me 5 years with only 1000miles on it. And I don't wanna blow it up or have something let go at 60 mph .
drain the oil?
look for metallic bits,probably will have some because it is still breaking in.
but if it had a lot I would pour the oil back in and take it back
I don't see what your engine size is other than a single cylinder as you stated. But! I have a 2012 550 and under hard acceleration in the mid range it sounds like the piston is going to come out. This is a common theme with the 550 Fuji motor as many other people have commented about it also. It does not seem to affect the performance and I have not had any problems.
Maybe ask the dealer if Polaris would also like to pay for all of you medical bills and the time you miss from work when it locks up on you going 45 mph or climbing a hill!
Has the dealer even looked at it? This is not something you should have to deal with.
That is totally what is sounds like the timing gear on the cam. Good call . And that was gonna be my next move is to tell the to message polaris and see if someone gets hurt or injured are they going to pay all my bills. . Ether way this is going back to the dealer tomorrow and staying there . And I'm gonna mention to them about the timing gear slipping on the cam. Thanks everyone for the input this is my first time posting anything online. .
Can you tell if the timing gear is one piece with the crank by the parts diagram? #1 is whole crankshaft assembly... There is no option to buy a timing gear.
I wish the cause of the problem was posted. I am having the same slapping sound when high rpm power5200+ maybe?)is being used. Idle there is no slapping.
just got done new crank and piston installed. Edit- about 70 miles into rebuild, and noise sounds like from the front
Are you sure its the engine? I had a loud vibration noise at increased rpm. It ended up being the snorkel. Try tie wrapping it to the bracket it sits on.
Yes. It was the valves hitting the piston. Timing a bit off. When moving engine around while off the vehicle, timing somehow skipped. Might have been when trying to check smoothness of pistons. My boy turned it reverse motion via the flywheel. Think thats when it got a bit off.
Got the engine done again. Just got to finish plastics and top with coolant tomorrow.
Why was the engine off the vehicle with only 52 miles on it? Note: if turning the engine backwards causes the timing to be off, it needs a new timing chain installed before it breaks and causes major (perhaps irreparable) damage.
That brings up the question, why would the timing chain be worn out after 52 miles? What's the full story here?
Latebird I just realized this is 6 year old post and that’s the bike with 52 miles! The one he’s talking about is another one with who knows how many miles before rebuild. Very good example of why you should start your OWN thread .
113.4K members
