570 12" whee570 wheels will NOT fit a 570SP. Thor's definitive answer. - Page 3 - Polaris ATV Forum
post #21 of 33 (permalink) Old 11-09-2015, 07:53 PM
Vandal's Avatar
Originally Posted by bobx2 View Post
Originally Posted by bp405 View Post
Yeah this doesn't prove anything as far as the 570sp and 12" rims are concerned. It only proves that stock rims don't fit. I'm willing to bet a 4+3 offset on a 12" rim will work on a 570sp.
Also this whole hating on 14" rims is a lack of knowledge and buying into misinformation. First of all 14" rims cause no more or no less pinch flats the 12" rims its the tires that wrap them is where the problem lies. In the off-road community the general rule of thumb is you want a 2:1 ratio tire to rim diameter. If the tire to rim ratio deviates to much from that ratio the user will run into problems. I run 26" tires on 14" rims and it is absolutely the best combo. To crunch some numbers my 26" BH 2.0's measure 26.75" @5psi. So on my 14" rim the ratio is 1.91:1. Don't buy into the misinformation 14" rims work just as good as 12" because there are pros and cons to each and basically the rider needs to make an informed purchase based on his riding style, needs, and environment.
And I'm willing to bet you are wrong. The OEM wheel has a 4+2 offset, and if you look at all the pictures, you will see the wheel is still at least an inch from being seated on the hub. A 4+3 offset gives you one more inch to play with, but it would still be against the tie rod end when fully seated on the hub.
As for 26" tires on 14" wheels being the absolute best, that is crap as well. If you just ride smooth, hard packed trails, I'm sure you would be on the money with that. My alleged "lack of knowledge" cost me $330 worth of tires, riding the exact same trails I had ridden for years with 12" wheels and 26" tires. Never had a flat prior to the two pinch flats, and haven't had one since going back to 12" wheels. Anyone who rides rocks knows the truth about the 26/14 inch combo. It simply is not suited for the job.
They say a picture is worth a thousand words. You have been offered up some 7,000 words worth of proof in this thread that actually, visually, show problems, and yet you continue to deny that the problems are real. If you would kindly go buy yourself a 570 SP and show us all how you fit 12", 4+3 offset wheels on it, then I could eat a helping of crow. Since someone who does actually own a 570 SP showed us all that a 12" wheel doesn't fit, I think my crow dinner is safe.
Bob....BP405 is from New York. I would bet you he hasn't seen the size rocks you guys out west ride on. He probably rides on the interstate....and for that 14's and 26's will work just fine. Lets face it.....the more sidewall the less pinches.Just makes sense
2016 570 RZR EPS Trail with EBS
Sunset Red
F+R windshields
Quadboss roof
Polaris Rear Cargo box
26X9X12 Maxxis Ceros
26X11X12 Maxxis Ceros
ITP SS 212 Machined wheels
UTV Giant V2 doors
Led Cubes
Polaris Low Profile front brushguard
Departed friends
2015 Polaris Ace 570
2001 Kawasaki Bayou 300 4x4, a great 3 wheel drive ATV
2013 Sportsman 500 HO another great atv
Vandal is offline
post #22 of 33 (permalink) Old 11-10-2015, 06:41 AM
bobx2's Avatar
Yeah, I know, and I shouldn't get my panties all wadded up over this topic. I just hate seeing wrong info put out there to people who might not know any better. I hope that sharing my experiences will maybe help someone else avoid the expensive problems that many of us have experienced, or at least understand the possible issues.
bobx2 is offline
post #23 of 33 (permalink) Old 11-10-2015, 06:57 PM
MTBill's Avatar
Add me to the list of guy's who've gotten a pinch flat with 14" wheels and 26" tires. I'll be going up to 27" or 28" tires.
Sent from my SAMSUNG-SM-G890A using Tapatalk
MTBill is offline
post #24 of 33 (permalink) Old 03-27-2016, 05:22 AM
Mizzo81570sp's Avatar
I have not had a pinch flat yet on my 26"x14" but I will be ordering 28" soon for my 570sp. and there are rocks in New York lol we don't all ride on the highway. We also have some trees even in the city.
Mizzo81570sp is offline
post #25 of 33 (permalink) Old 05-04-2016, 04:39 PM
RTICKWAD's Avatar
Okay I bought 26" BigHorn tires wheel kit for my Grizzly I sold last year. Won't for my 570 based on different bolt pattern .The are the 12". So if I find a new 12" wheel kit to have the tires mounted on, will they fit my 570 (EPS) non SP Camo model (2016).
Thanks for your help!
R'
RTICKWAD is offline
post #26 of 33 (permalink) Old 05-04-2016, 05:31 PM
bobx2's Avatar
Put them on a 12" wheel with a 4+3 offset and they will be perfect for your 570. I'm assuming they are 26-9-12 and 26-12-12 sizes.
bobx2 is offline
post #27 of 33 (permalink) Old 05-04-2016, 05:40 PM
RTICKWAD's Avatar
Yes your right Bobx2. My wheel size is 12x7 per the dealer and the tires sizes front and rear like you said. Okay next question, any recommendations on this replacement wheel kit? What hot, cool, lighter and stronger these days?
Thanks,
R'
RTICKWAD is offline
post #28 of 33 (permalink) Old 05-04-2016, 06:16 PM
ThorsHammer's Avatar
personally I don't waste my time looking for wheels. they really do very little to affect the riding. All they are is lipstick on a pig for me. I'm not out there to look cool, I'm out there to have a good time so stock wheels are fine with me. besides, that's money that can be spent on other accessories that actually help riding. like a winch, hand guards, rack extensions, extra gas tanks, etc..
25" STI Black Diamond ATRs
Pure Polaris hand guards
4" LED on the pod
Tamarack Titan Luxury Lounger
Cabela's Chainsaw mount
Quadworks Stage 1 power kit
  • Dynojet kit
2" rear spring spacers
Towable/equipment
Custom built road drag grader
Future mods
Rear bumper/brush guard
ThorsHammer is online now
post #29 of 33 (permalink) Old 05-04-2016, 06:21 PM
RTICKWAD's Avatar
Good points. Even this tire guy said pretty much the same while comparing ITP, STI etc. basically getting the same output. In sure some will differ but seems like that's the consenus. Okay great thanks for the info y'all!!
R'
RTICKWAD is offline
post #30 of 33 (permalink) Old 05-04-2016, 06:48 PM
Banned
Markcuda's Avatar
How can you with this)))))))))))))))))))))) 2007 Hawkeye 300 17HP of gutless glory
Markcuda is offline
2014 Polaris 400HO 14" Wheels 28" Zillas WILL THEY FIT? OneLuv1979 ATV Wheels & Tires 4 09-05-2014 10:19 PM
Question about MSA wheels "Kore" ARKXP Polaris XP 0 05-28-2013 02:59 PM
Thor Ride pants (44) & Thor Phase jersey (XXL) chronix79 ATV Parts for Sale 7 11-13-2012 10:20 AM
Best "All 'round" tire that will fit 2012 850XP HO stock steel wheels Nayrlladnar ATV Wheels & Tires 14 06-12-2012 06:38 AM
Why No, Aftermarket "standard", Wheels phil ATV Wheels & Tires 6 10-18-2010 08:19 PM
