2017 xp 1000 le top speed ? - Polaris ATV Forum
 1Likes
post #1 of 30 (permalink) Old 04-17-2017, 05:55 AM Thread Starter
wkeggenhoff's Avatar
Anyone with a new 2017 xp 1000 sportsman what are you seeing for top speed ?
Took mine out yesterday and was pretty sure was banging rev limiter at 120kmh on paved rd. Didn't get a chance to look at rpms though. Only have 4 hrs on bike and just gave it a quick crack down rd. Was 90% sure was in performance mode not standard
Do they have any kind of break in mode like sleds. ?
From what Ive heard this bike should approach near 80mph stock ?
Was hoping not to have to reflash ecm yet or re-clutch ? Yes i know it not a race quad but we do a lot of high speed forestry roads, i get it. But i bought a 1000 for a reason
Can tell you one thing this thing pulls like a bear from 80 km/hr roll on to 120.
I know there is a speed limiter in work mode of 70km/hr, is there a limiter in standard mode ?
thanks
2017 Xp 1000 Sportsman LE Matte Cooper
2008 843cc Yamaha Grizzly
wkeggenhoff is offline
post #2 of 30 (permalink) Old 04-17-2017, 07:13 AM
jhalpinjr's Avatar
My 2016 850 Touring with almost bang 76mph on the road, stock.
Make sure you are in performance mode. Most of the reviews I have read say 80mph is top speed for the 1K.
2017 Polaris Sportsman XP1000: Test | ATV Rider
2016 Sportsman Touring 850SP
Ricochet Full Armor- Anodized Red
Rick Cecco Frame Bracers
Gorilla Whips - Silverback LED Whip
ATV-Guru Rear Bumper
RAM Mount- Use Polaris RideCommand App
jhalpinjr is offline
post #3 of 30 (permalink) Old 04-17-2017, 07:24 AM
FUSE's Avatar
82mph out of mine on a flat stretch of highway with little to no wind.
FUSE is offline
post #4 of 30 (permalink) Old 04-17-2017, 10:49 AM
Battle_Design's Avatar
Should be around 80 mph give or take depending on weight.
850 XP
Battle_Design is offline
post #5 of 30 (permalink) Old 04-18-2017, 09:14 AM Thread Starter
Well hoping then that I just wasn't in performance mode and that top speed is limited in standard mode. Hopefully can get out again this weekend and recheck.
Thanks for the feedback
post #6 of 30 (permalink) Old 04-18-2017, 03:24 PM
thumper1500's Avatar
I've had my 2015 1000 Touring up close to 85 (tires pumped up fairly firm), not sure exactly where because my eyes were glued to the road I've heard claimed that it's speed limited to 86.
2015 Sportsman XP 1000 Touring
Bronze Mist
QSC Clutch Kit
Ricochet Ultimate Armor Kit
HighLifter 2" lift kit
Kenda Bearclaw HTR 28" tires
Cecco frame braces
Cecco billet front pinion cover
Guru silver bumpers
12" LED lightbar
2" hitch w/bottle opener
Mid smoke windshield
Tatou 4s tracks for the snow
Synth winch line and Hawse fairlead
LED headlights
Wired for electric helmets
thumper1500 is offline
post #7 of 30 (permalink) Old 04-20-2017, 02:01 PM
trusselo's Avatar
I found my 2015 to be quite squirely over 100 km/h with the stock tires. didnt push it much higher for more than a few seconds. plenty of throttle left.
however... with my new 29" radials... hahaha. doing over 100 km/h on (or off) road is AMAZING!!!
120 km/h easy.
add high flow exhaust and intake..... flash PCM... nos/ turbo... you'll be able to generate 1.21 Giggawats to take you back to the future.
2015 Sportsman XP 1000 PPCamo
3x 100W HID light kits - Wireless Winch
RAM Camera Mount from gpscity.ca
Tigertail from FortNine.ca
2 inch lift - 4 inch spacer kit - Fender Flares
Heated Seat kit & Camo seat skin
Heated Hand & Thumb Kit - 12" Cree light bar
Cecco Frame Braces - AMSOIL Front Drive Fluid
Dalton Clutch kit - Triangle ATV Stealth Snorkel
29" Traxion ICE Gripper MAX Studded Tires
In progress ... reverse lights, turn signals and horn
Wish list.... HMF exhaust / re-flash
trusselo is offline
post #8 of 30 (permalink) Old 04-20-2017, 03:54 PM
jhalpinjr's Avatar
120 km/h easy.
Part is psychological. When you change the diameter of the wheel size you impact the speedometer.
These machines need to tire revs per mile programmed in the ECU to calculate speed. Changing tire diameters changes the speedo.
Older units are not that way, but still calculate similarly.
post #9 of 30 (permalink) Old 04-20-2017, 05:53 PM
trusselo's Avatar
you have it backwards.... and wrong.,
The difference between stock 26" tires and my 29" would make the bike go FASTER than the speedo says.
using an online calculator
Calculator - Speedometer Adjustment for Tire Size Change | Interco Tire
ANNNNDDDD.
the stability at high speed is because the new tires are RADIAL not biased. that is a known and proven fact of radial tires.
so wrong and wrong
nothing psychological
trusselo is offline
post #10 of 30 (permalink) Old 04-20-2017, 05:59 PM
jhalpinjr's Avatar
ANNNNDDDD.
so wrong and wrong.
First I never said anything about your speed and and how it correlated being higher and lower compared to your size. I was explaining in a general matter that tire size has an effect on the speed. I don't need the calculations- I program ECUs everyday.
** Edited due to language **
Initial Thoughts after 2017 Sportsman 1000 Purchase BroncoBoy Polaris Sportsman XP 1000 21 04-01-2017 07:39 PM
2017 Polaris Sportsman 450 HO top speed video creed82 Polaris Sportsman 10 03-27-2017 04:16 PM
2017 Sportsman or Outlander 1000 Hunter Editions MN76 Polaris Sportsman XP 1000 7 02-13-2017 12:23 PM
2017 Polaris sportsman 1000 Craigslist ad, real or not? Walbertt ATV Purchasing and Price 7 02-13-2017 07:23 AM
Sportsman 1000 top speed issue. FrankXp1000 Polaris Sportsman XP 1000 33 02-25-2016 04:57 PM
