the reverse overide allows you to go in reverse just as fast as forward...otherwise it is set to cut out for safety reasons... works great if your stuck and allows more tire spin in reverse
make sure the throttle control is adjusted properly or it could be the rev limiter module itself, disconnecting the black wire from the the rev limiter to the cdi will take it out all together, make sure you have a battery in it, hope this helps
113.2K members
