2004 sportsman 700 carb problems - Polaris ATV Forum
post #1 of 11 (permalink) Old 12-17-2010, 12:04 PM Thread Starter
JWP
JWP's Avatar
I bought a 2004 sportsman 700 project and have had a rough time with it. I am getting close to getting it together and am having troubles with the carburetor. It had a hesitation in it and rough idle so decided to rebuild. After I rebuilt it, it will only run with the choke pulled out. Once it is pushed in, it dies completely. What could be wrong? I replaced everything except the diaphagm assembly. Could that be the problem.
JWP is offline
post #2 of 11 (permalink) Old 12-17-2010, 12:35 PM
cookies's Avatar
sounds like your pilot jet needs to be turned out a bit. did you by any chance screw it in all the way when you replaced it and forgot to turn it out?
cookies is offline
post #3 of 11 (permalink) Old 12-19-2010, 05:40 AM
SPORTSMAN70003's Avatar
Check the carb boot between the carb and head. They are very prone to cracking.
F.A.S.T Racing
POLARIS 800,STAGE II TURBO,CHEMICALLY INTERCOOLED,NITROUS,40MM CARB,DIRTY DAWG CLUTCHING,CUSTOM MUZZY EXHAUST,CUSTOM RACE CUT & PAINTED PLASTIC, SCRAMBLER BUMPER,28" MUDZILLAS W/TORK WHEELS,ITP HOLESHOT'S,NERF BARS,OIL & TEMP GAUGES,K&N FILTER,3"WHEEL SPACERS,HEADLIGHT & REVERSE MOD,2" RD LIFT,SNORKELED
SPORTSMAN70003 is offline
post #4 of 11 (permalink) Old 12-19-2010, 06:09 AM Thread Starter
JWP
JWP's Avatar
Which jet are you referring to? when you look at a schematic, there is 2 pilot jets.
JWP is offline
post #5 of 11 (permalink) Old 12-19-2010, 06:33 AM
Both!
polman500 is offline
post #6 of 11 (permalink) Old 12-19-2010, 09:51 AM
cookies's Avatar
there is only one pilot jet, it's on the front (engine side) lower part of the carburetor. Turn it 1.5 - 2 full turns out (counter clockwise) from being snug.
cookies is offline
post #7 of 11 (permalink) Old 01-12-2011, 07:45 AM Thread Starter
JWP
JWP's Avatar
I finally got back to working on this thing last night and got the idling problem fixed. When I had rebuilt the carb, I had left the pilot jet in there since it had that brass cover. With me soaking the carb, the rubber gasket messed up. Last night I took it out and replaced the pilot jet. It will now idle.
My problem now is that when you give it gas, it will bog down and die. Where do I go now with this problem.
JWP is offline
post #8 of 11 (permalink) Old 01-12-2011, 06:21 PM
cookies's Avatar
hmmm... are you letting it warm up before you try to give it throttle? did you put the e-clip in the middle position of the needle when you rebuilt the carb? still sounds like a carb problem to me.
cookies is offline
post #9 of 11 (permalink) Old 01-13-2011, 06:44 AM Thread Starter
JWP
JWP's Avatar
I pulled the carb again last night and took it apart completely and put it back together. Did not find anything out of the ordinary. I remember what some one had said about the intake and inspected it. Sure enough, it has a crack in it. Probably been the problem all along.
JWP is offline
post #10 of 11 (permalink) Old 01-13-2011, 08:04 AM
Razorback's Avatar
Yeah, those cracked boots will cause all kinds of headaches till you finally figure out that's what it is.
Razorback is offline
2004 sportsman 700 electrical problems FIXED!! cmpetes ATV Repair and Maintenance 4 02-27-2012 12:52 PM
2004.5 sportsman 700 carb/choke problems????? Vahoagie ATV Repair and Maintenance 6 12-04-2010 09:39 AM
2004 Magnum 330 Sportsman Front End Problems beasleys ATV Repair and Maintenance 4 07-30-2010 02:25 PM
1993 Sportsman 350 Carb Problems sjd1198 ATV Repair and Maintenance 1 11-17-2009 05:06 PM
2004 ATP Carb and throttle up problems nuckinfuts ATV New Members 5 10-01-2009 08:17 PM
