Best Battery? - Polaris ATV Forum
post #1 of 15 (permalink) Old 12-21-2010, 08:19 PM Thread Starter
pondfishr's Avatar
Best Battery?
I need to replace the stock Polaris battery on my 2007 Polaris 500. What is the best replacement to buy while considering the unit has a Warn MT3000 winch?
pondfishr is offline
post #2 of 15 (permalink) Old 12-21-2010, 10:57 PM
Ghost Rider's Avatar
Yuasa batterys are good, and ive used them before and never had any problems with them. There are other batterys available but i have no experiance with them.
2011 Sportsman XP 550 EPS
Front And Rear Rack Extensions, Rear Lock And Ride Box With Back Rest, Heated Hand Grips, winch, Fender Extensions, Front And Rear Bumpers, HID Lights, A-Arm Guards, Low Lock And Ride Windshield, Maxxis BigHorn 2.0 Tires.
Ghost Rider is offline
post #3 of 15 (permalink) Old 12-22-2010, 02:26 AM
Smoothbassman's Avatar
In the case of ATVs I don't think any one is better than the others. Get a Yusa AGM or GEL battery, they typically have more deep cycle capability to help with your winching needs. More importantly, solid battery maintenance will go a long way to keeping your battery around for a long time. I have a dual Battery Tender on my 2 quads batteries at all times to keep them from sulfating. Wife's quad starts just like new every time after six years of use.
  • Polaris 3500 Winch
  • Elka Stage 2 Triple Rate Shocks with Rebound
  • Hand Warmers
  • Garmin GPSMap 62S
  • 27" Grim Reapers
  • 8000K HID Lights
  • Ricochet Full Skid Kit
  • Go Pro Hero 3 Black Edition
Smoothbassman is offline
post #4 of 15 (permalink) Old 12-22-2010, 04:48 AM
tt425's Avatar
AGM (absorbed glass mat) battery I think is the best.
tt425 is offline
post #5 of 15 (permalink) Old 12-22-2010, 07:41 PM Thread Starter
pondfishr's Avatar
Thank you for the information I really appreciate it. With your help I can make a better informed purchase.
post #6 of 15 (permalink) Old 12-23-2010, 04:16 AM
tt425's Avatar
you are welcome
tt425 is offline
post #7 of 15 (permalink) Old 12-23-2010, 04:26 AM
Diesel man 03's Avatar
I think most batteries a good as long as you do the maintenance on them,keep the terminals clean and if they are the type that require water keep the cells up to level, also charge it up right away if it happens to get run down.
Diesel man 03 is offline
post #8 of 15 (permalink) Old 12-23-2010, 04:23 PM
ray14sher's Avatar
Send a message via AIM to ray14sher
I agree with smoothbassman get a Battry Tender and whatever you buy should last for years.
ray14sher is offline
post #9 of 15 (permalink) Old 12-23-2010, 04:55 PM
North Branch's Avatar
The guys are right. I've tried numerous batteries over the years, and the newer Yusa AGM batteries are probably the best. Using a good battery tender will make them last a long, long time.
Here's the IMPORTANT thing... DO NOT let the dealer or somebody at the place of purchase "prep and charge" the battery. Make them fill the battery in front of you... and then you take it home and let it sit for a few hours. Then, take a good 1 1/2 to 2 amp charger ( like a Shumacker 1.5 amp charger/maintainer), and let the charger do it's work. By letting the electrolyte be absorbed in the battery over a few hours time, and by letting the small amperage charger bring it up to full charge slowly, you'll get maximum life out of the battery (provided it is maintained properly).
Here is the perfect charger for the initial (or subsequent charges) and for maintaining the battery...
North Branch is offline
post #10 of 15 (permalink) Old 12-24-2010, 10:23 AM
mechanike's Avatar
yeah the AGM battery is great!!!! i remember when my b.i.l. owned this 250 he never maintained anything and it wouild sit for months. then i would come over to ride it and it would also be flooded out from a bad float valve he should have replaced.so it would crank alot until it finally started after sitting forever and i was amazed how fast it turned over after sitting so long.did i get the message across after all that double talkin????? Happy Holidays.
mechanike is offline
replaced starter- battery cable still melting conections and dead battery mcmarkrazz Polaris Sportsman 4 09-19-2010 07:20 PM
Battery? mutt3497 ATV Repair and Maintenance 2 08-12-2010 04:14 PM
04 Polaris Sportsman 700- Battery cable melted battery?? clarksofky Polaris Sportsman 3 12-24-2009 06:45 AM
Battery Problems.... please help... shack502 Polaris Sportsman 7 12-09-2009 01:45 AM
Battery drain springahd ATV Repair and Maintenance 2 11-18-2009 02:34 PM
