TPS Adjustment on New Throttle Body Assembly - Polaris ATV Forum
post #1 of 3 (permalink) Old 09-14-2016, 02:25 AM Thread Starter
pglover19's Avatar
I just purchased a new throttle body assembly for my 2007 Sportsman 500 EFI and it already has the TPS attached to it from the factory. On the new throttle body assembly, do I need to do any adjustment to the throttle position sensor at all. I was told that the sensor is set at the factory and I should not loosen or adjust the sensor.
So is the install of the new throttle body assembly with the TPS attached just plug and play? Please advise.
pglover19 is offline
post #2 of 3 (permalink) Old 09-14-2016, 03:05 AM
bp405's Avatar
Only adjustment I'm aware of is the throttle cable.
2011 sportsman 800 efi
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
bp405 is offline
post #3 of 3 (permalink) Old 09-14-2016, 05:20 AM
The TPS is already set from the factory. DO NOT LOOSEN OR MOVE IT! If you do it will have to be re-calibrated to set the correct voltage.
polman500 is offline
Scrambler 850 stuck throttle check engine light tjp2473 ATV Repair and Maintenance 0 09-12-2016 12:22 PM
WTB Thumb Throttle assembly ZuluWhiskeyFox ATV Parts Wanted 0 08-21-2016 05:54 PM
Throttle stop set screw badwithcomputer ATV Repair and Maintenance 6 07-03-2016 06:03 PM
850 throttle issue aceman ATV General Discussion 2 05-10-2016 10:21 AM
