08 Sportsman 800 4x4 wont engage - Polaris ATV Forum
Old 01-22-2011, 07:15 PM
frazier's Avatar
Member #11316
After I start playing in the mud my 4x4 wont engage when I put it in hi or low but will engage in reverse if I hit the override button. Has anyone had this happen and does anyone have a fix?
Old 01-22-2011, 07:34 PM
cookies's Avatar
Member #8052
is the display showing the correct gear when you are in H or L? is the AWD symbol showing up when you switch it on?
Old 01-22-2011, 08:11 PM
frazier's Avatar
Member #11316
Yes it shows all the gears and the 4x4 Icon comes on the front wheels just wont pull.
Old 01-22-2011, 10:44 PM
cookies's Avatar
Member #8052
check the gray and brown/white wires that go TO the gearcase for 12v dc. check the gray and brown/white coming FROM the gear case for resistance. should be 24ohms.
make sure to test while the machine is switched on (not running) and in gear H or L - in otherwords display will show h or l gear and 4x4 icon while you test.
Old 01-23-2011, 05:36 PM
frazier's Avatar
Member #11316
Those wires hook up to the front hub on the back side? Just want to make sure I test the right wires.
Old 01-23-2011, 06:04 PM
cookies's Avatar
Member #8052
yes, the wires that go into the front hub coil. should if you can see them under the insulation they are grey and brown/white striped.
Old 01-24-2011, 04:21 PM
frazier's Avatar
Member #11316
Everything checks out ok could it be something else.
Old 01-24-2011, 05:39 PM
cookies's Avatar
Member #8052
have you checked the fluid in the front gearcase? should be to the top of the fill plug threads and should be clean of water and dirt. might want to try to drain and replace it before you move onto tearing the gearcase apart.
Old 01-25-2011, 03:49 PM
frazier's Avatar
Member #11316
ok now I am stumped. I checked the fluid and it was clean so i jacked it up off of the ground and put it in 4x4 and it will try and lock in 4x4. So i put it up to a tree and locked it in and it locked in one time but when i put it in rev and pushed the override button it would not lock in and low and behold I put it back in low and high and it would not lock back in. Thanks for all your help I will try anything.
Old 01-25-2011, 05:49 PM
cookies's Avatar
Member #8052
sounds like your next step is gonna be to disassemble the gearcase, i cannot think of anything else it could be on the outside.
08 polaris 4x4 not working
08 sportsman 4x4 problem
08 sportsman 800 4x4 not working
2011 polaris sportsman 800 4x4 does not work in reverse
2011 sportsman 800 4x4 in reverse
polaris 800 4x4 wont engage in 4wd
polaris sportsman 500 4x4 wont engage
polaris sportsman 800 4x4 fix
polaris sportsman 800 4x4 not working
polaris sportsman 800 4x4 not working in reverse
polaris sportsman 800 4x4 problems
polaris sportsman 800 4x4 wont engage
00 sportsman 335 4x4 wont engage vortecman07 Polaris Sportsman 16 01-24-2013 01:06 AM
trailboss 4WD wont engage jeepster651 ATV Repair and Maintenance 2 08-10-2010 10:41 AM
94 300 4x4 reverse grinding and wont engage pikeguy47 Polaris Sportsman 3 01-17-2010 01:12 PM
2002 sportsman 700 4x4 wont engage REDNECK74Z71 Polaris Sportsman 4 10-15-2009 06:22 PM
05 sportsman 4x4 wont engage mikgro ATV Repair and Maintenance 2 09-13-2009 02:49 PM
