  #21 (permalink)
Old 01-31-2011, 01:02 AM
camo75's Avatar
Member #11202
i have a stupid question what do i need to do to get my reverse lights to come on when selecting reverse?
I put a meter on the conntection today and when in reverse i had no power to the work light globe.
I am a little confussed with your mod. Do i need to do it to get my lights to come on when i select reverse or do i need to do something else?
  #22 (permalink)
Old 01-31-2011, 05:35 PM
QuickSilver74's Avatar
Member #10522
this mod is what makes the work lights act as reverse lights. they dont function that way from the factory
2007 Sportsman 800
2" lift, 14" ITP rims, 30" Zilla's, QSC clutch kit, 3 headlight mod
NEW, AUTOmatic reverse limiter bypass and reverse light mod, no more annoying switches!!
click here for instructions
  #23 (permalink)
Old 01-31-2011, 11:17 PM
camo75's Avatar
Member #11202
ok thanks i had a closer look today and a found if i put a switch on the socket (under the speedo) i get power to the rear work light so this will be fine what i do with the bike (its used on or farm).
Now for the stupid question what type of globe do i go and buy for the work light. Today i went into my local auto elec to get some globes and he was unable to help me. I went to my local Polaris dealer and they told me they never had them in stock and would have to order them in. I know we are a little slower over here in Australia but surely i should be able to go into my local parts supplier and purchase some globes. (while you are answering my stupid question dont forget to tell me the wattage for the globe)
  #24 (permalink)
Old 02-01-2011, 04:33 AM
Member #10522
you can use either a 912 or 921 bulb. the 921 is brighter, so that is what i used. i got a pair of them for $5 from the local parts store
2007 Sportsman 800
  #25 (permalink)
Old 02-01-2011, 07:49 AM
05sportsman800's Avatar
Member #7558
just did this mod on my 05 800 works awsome !!!!!!
  #26 (permalink)
Old 02-01-2011, 12:00 PM
utahjaun's Avatar
Member #11470
when i do this mod and have the switch off so i can go int diagnostic mode does it go back to the way it was before and shut down the motor when in revers so i dont need to worie whe n my kid is riden it
o8 sprotsman 500
  #27 (permalink)
Old 02-01-2011, 12:10 PM
Member #10522
Yes, with the switch off all the limiters are just like factory.
2007 Sportsman 800
  #28 (permalink)
Old 02-01-2011, 12:56 PM
utahjaun's Avatar
Member #11470
Great thanks off to cut some wires
o8 sprotsman 500
  #29 (permalink)
Old 02-01-2011, 03:31 PM
08sporty800's Avatar
Member #10706
just finished doing this to my 08 800, works EXCELLENT thanks for the write up, dont think i woulda ever figured that one out myself (I HATE WIRES haha) so happy to be able to use my rear winch and still be in 4X4 and never to have to push that button for 4X4
cheers
2008 Polaris Sportsman 800, 28" Gorilla Silverbacks, EPI Clutch Kit, front and rear 2500lbs winch, 3 headlight mod, reverse override mod, hand and thumb warmers
2006 Ski-Doo MXZ Renegade 1000sdi, 136" X 1.25" Paddle Tack
1986 19.5 'Bayliner Capri w/ Force 125
1980 Arctic Cat Jag 340
1984 Honda CR125
2001 GMC Duramax 2500HD Crew Cab 4X4
  #30 (permalink)
Old 02-01-2011, 03:37 PM
utahjaun's Avatar
Member #11470
ok i have the pod off and there is 2 plugs on the speedo and there is 1 that is there with nothing pluged into it
is the 1 that does not have anything pluged into it the one i need
o8 sprotsman 500
08 sportsman 800 reverse 4x4 override
4 prong switch
atv reverse light switch
best mod on sportsman 800
how to put older sportsman in reverse
polaris reverse light
polaris reverse override switch
polaris rzr wiring diagram for fog lights
polaris sportsman backup lights
polaris sportsman reverse light
polaris sportsman reverse override mod
polaris sportsmanwork light reverse mod
relays 5 pin
rzr auto reverse light
Reverse override mod ratlnram Polaris Sportsman 36 06-06-2011 11:01 AM
Reverse override n2mudn ATV Repair and Maintenance 0 07-08-2010 06:43 PM
Reverse override? hallj86 ATV Repair and Maintenance 2 05-09-2010 06:41 AM
4x4 reverse override ploughboy ATV Repair and Maintenance 3 02-10-2010 10:36 AM
reverse override kclidwell ATV General Discussion 4 01-31-2010 05:31 AM
