2006 sportsman 500 efi fan not coming on - Polaris ATV Forum
post #1 of 21 (permalink) Old 02-16-2017, 03:59 PM Thread Starter
jbanta1983's Avatar
Exclamation 2006 sportsman 500 efi fan not coming on
Bought this quad used about months ago had around my back yard with no problems at all. 1st time i took it out and did some hard riding it shut down on me about 30 minutes into the trip while riding in a shallow stream. I waited about 30 seconds and it started right back up. I never heard the fan come on and didn't notice the dashboard flashing HOT. It rode fine for about another 20 minutes then sputtered like it wanted to shut down but never did then i took it back home. Since then i have installed a new thermostat, a new thermistor, and a temperature gauge with a fan bypass switch. I got the engine up to 195 degrees today and still no fan. When i use the switch to manually turn it on it does its job and cools the engine pretty quickly. I have 2 questions that hopefully someone can answer.. 1. What is the cause of the fan not turning on itself? and 2. If i manually control the engine temperature by turning the fan on and off as needed will it still cut out or will i be ok? What actually tells the engine to shut off? and incase you are wondering, Yes this quad was under the ecm recall and it was replaced.
jbanta1983 is offline
post #2 of 21 (permalink) Old 02-17-2017, 07:04 AM
maverick18's Avatar
Replace circuit breaker and call it a day. Went through same issue. $5 part at auto parts store. Buy a 30 amp. No need to tape it or seal it. It runs cooler with out it covered.
Sent from my SAMSUNG-SM-N920A using Tapatalk
maverick18 is offline
post #3 of 21 (permalink) Old 02-17-2017, 07:05 AM
maverick18's Avatar
post #4 of 21 (permalink) Old 02-17-2017, 09:47 AM Thread Starter
jbanta1983's Avatar
ok where do I find that fuse at on the quad?
post #5 of 21 (permalink) Old 02-17-2017, 09:48 AM Thread Starter
jbanta1983's Avatar
and thank you maverick18
post #6 of 21 (permalink) Old 02-17-2017, 10:56 AM
maverick18's Avatar
Under the pod
post #7 of 21 (permalink) Old 02-17-2017, 10:56 AM
maverick18's Avatar
post #8 of 21 (permalink) Old 02-17-2017, 03:45 PM Thread Starter
jbanta1983's Avatar
i could not find anything like that on mine. What year is yours?
post #9 of 21 (permalink) Old 02-17-2017, 03:46 PM Thread Starter
jbanta1983's Avatar
i could not find anything like that on mine. what year is yours?
post #10 of 21 (permalink) Old 02-17-2017, 04:39 PM
maverick18's Avatar
Mine is a 2005 sportsman 800
Tags
overheating sportsman
Blown engine worth fixing? Aedude006 ATV Repair and Maintenance 13 03-03-2016 06:56 PM
