Old 02-20-2011, 05:09 PM
ryan1234's Avatar
Member #12224
Sportsman 700 EFI Bogging
Hi there
I am new to the forum and am looking for some help. I have a sportsman 700 EFI. I believe its a 06-07. It will not rev above 5000 rpm even at full throttle. Almost like its in some kind of limp mode. Every once and a while it will get half second blips of power and then at one point during the day i had full power for about 2 minutes. I added new fuel to it part way through the day and it helped a bit. I wanted to get your opinions before i started taking things apart. I think its either the fuel filter, fuel line or spark plugs. The battery is fully charged. Probably was bad fuel then plugged the fuel filter??
Old 02-20-2011, 05:55 PM
Old 02-20-2011, 06:49 PM
T Hunter's Avatar
Member #12135
I worked on an 06 500 that had a similar problem. It would run good for a few minutes and then start bogging down under half to full throttle and for a few seconds would run good. After doing a tune up and changing the fuel filter and getting nowhere, i noticed if i turned it off for as little as 30 seconds it would run good again for a few minutes and then i decided it was the fuel pump getting hot and not making enough pressure. I swapped the pump out and it hasn't missed a lick since. Not sure this is the same problem you have but definately worth checking into.
02 Sportsman 700 custom bumpers & 27" 589s
01 Sportsman 500 HO Ducks Unlimited Edition
Old 02-20-2011, 06:55 PM
T Hunter's Avatar
Member #12135
Also might want to check the battery connections which if loose can make computer controlled engines do funny things and the sensor between the throttle body and the intake is a problem on some models from the wire loom rubbing through the wires.
08 polaris ranger bogging
08 sportsman 800 bogs
2008 dragon 700 bogging at full throttle
2008 polaris ranger 700 fuel filter
2008 sportsman 800 efi limp mode
2010 polaris ranger 800 bogs with no power
700 sportsman bogs at full throttle
loose power at half throttle on polaris ranger 700
my polaris 700 sportsman boggs down when reving engine
polaris ranger 700 bogging down
polaris ranger 700 boggs
polaris ranger bogging down
polaris sportsman 700 efi bogs
where is the fuel filter on a polaris ranger 700
Sportsman Bogging Down matthewprenger Polaris Sportsman 22 08-20-2012 12:59 PM
sportsman bogging mudjunkie ATV Repair and Maintenance 24 07-11-2011 08:49 PM
400 sportsman bogging out 1s1k ATV Repair and Maintenance 8 12-12-2010 05:32 PM
04 600 sportsman bogging out nowhereman ATV Repair and Maintenance 16 04-16-2010 04:25 PM
96 sportsman bogging no top end gwhunter ATV Repair and Maintenance 9 12-17-2009 03:10 PM
