500 wont start - Polaris ATV Forum
post #1 of 8 (permalink) Old 09-21-2009, 04:38 PM Thread Starter
sunshine's Avatar
Question 500 wont start
I have a sportmans 500,- 1999. It wont start when I use the key and start button.
1. It will pull start. 2. Use a screw driver on solenoid and it will start. 3. Let it run for awhile and turn it off. Let it stand for a miinute or two and it will start sometime with the key and start button. 4. The battery is good - check it. 5. let stand over night and won't start by key and start button.
anyone have any good glues.
sunshine is offline
post #2 of 8 (permalink) Old 09-21-2009, 04:42 PM
Bruce! is offline
post #3 of 8 (permalink) Old 09-21-2009, 04:47 PM
stickem's Avatar
bad conn. on the key switch..?
stickem is offline
post #4 of 8 (permalink) Old 09-23-2009, 10:30 AM Thread Starter
sunshine's Avatar
Question 500 won't start
check key wiring - seems o.k.
sunshine is offline
post #5 of 8 (permalink) Old 09-23-2009, 01:14 PM
MUDDIE49's Avatar
Sounds like dirty connections....or a starter problem...check the voltage going to the starter...it should be 11 to 12 volts...if it is...problay a starter..MUDDIE49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System. 2010 camo
SunPro Temp gauge. 550xp Sportsman
Xbow Gripper mount
~DOWN&DIRTY~
MUDDIE49 is offline
post #6 of 8 (permalink) Old 09-23-2009, 03:08 PM
pop
pop's Avatar
i had that problem a month ago on 2001 sportsman 400. found bad starter sw on left bar. bought used one on ebay. no problems. if i held sw up and wiggled left and right it would work sometimes. jumping sol also started it.
01 sportsman 500 with 1200 mi., moose carb kit. My third machine. Wifes = 2001 sportsman 400 (past 8000mi.) she does a lot of riding. Her second machine. My ride kawie prairie 650 with a diamond G dg5 hole shot mod.
pop is offline
post #7 of 8 (permalink) Old 10-02-2009, 02:00 PM Thread Starter
sunshine's Avatar
How would someone test a solenoid to make sure its working? This maybe my problem on not starting.
sunshine is offline
post #8 of 8 (permalink) Old 10-02-2009, 08:37 PM
pop
pop's Avatar
run a jumper wire from battery to small terminal on solenoid. if it turns starter it's good, check handle bar switch and wire to solenoid small terminal with key on and switch up, should be 12 volts. If it clicks check voltage on starter side of solenoid. should be around 12 volts while jumping. if there is go to starter. if solenoid clicks or not and no voltage on starter side solenoid bad.
pop is offline
Tags
sunshine
