Looking for a replacement CDI... - Polaris ATV Forum
post #1 of 8 (permalink) Old 03-01-2011, 04:46 PM Thread Starter
Cypher's Avatar
Angry Looking for a replacement CDI...
I have an '03 600 Twin. It died just after hunting season started. I have managed to find the service manual and have followed the instructions to troubleshoot a no spark problem. I am in spec for everything I can test except the CDI. I cannot find one for less the a couple of hundred bucks. Does anybody have any sources they would be willing to share?
Cypher is offline
post #2 of 8 (permalink) Old 07-12-2011, 09:35 PM
blflach's Avatar
Post
I have the same problem. Where do we find the parts???
blflach is offline
post #3 of 8 (permalink) Old 07-13-2011, 03:58 AM
not sure but maybe rickie stator on e-bay
Russ C is offline
post #4 of 8 (permalink) Old 07-13-2011, 04:41 AM
evilbay
polman500 is offline
post #5 of 8 (permalink) Old 07-13-2011, 07:24 AM
NaplesMudder's Avatar
Take a look at cheapcycleparts.com or bikebandit.com Both will have every part you can think of OEM and aftermarket. Their prices are pretty similar although CCP usually is cheaper. SN: beware ebay when it comes to OEM. I just ordered a fuelpump for my P/U that cross referenced fine, but when i got the part it was incorrect. Good luck and hopefully you are up and playing again soon!
2005 Polaris Sportsman 700 Twin - Green -
27" Bear Claws StI HD alloy rims
Uni air filter
Kolpin rear Storage w/cooler
Front Brushguard
Rear Brushguard
3 Headlight Mod
2up Footpegs
Pure Polaris Handguards
Stage 1 Dynojet kit
1998 Kawasaki Bayou 220 Yard mule
NaplesMudder is offline
post #6 of 8 (permalink) Old 07-13-2011, 03:49 PM
Kendo's Avatar
This was a known issue with the 02-04 Sp 700's. Polaris has a retrofit kit for it, to the tune of $500!! I did mine, took me the better part of a day but the quad starts and runs better than ever. I'm not sure if the 600 is in the same boat, but it is very possible. The part number for the kit is 2202603, and most of the online parts houses carry it.
2004 Sportsman 700 - battle tested and proven!
2008 Sportsman 500 EFI - hers
2011 Sportsman 850 XP EPS - the new guy
Kendo is offline
post #7 of 8 (permalink) Old 07-13-2011, 06:57 PM
jimh873's Avatar
Smile I have a CDI
I have a CDI for a 2008 Polaris Sportsman 500 HO. They go for a little over $200 but I am willing to sell it for a decent offer.
jimh873 is offline
post #8 of 8 (permalink) Old 08-09-2011, 07:19 AM
spoke192's Avatar
I have the same problem on a Sportsman 600 and I ordered the 2202603 kit from partshark.com. I am trying to install it and it looks like the wire connections are a little different than the old one. I am not sure if I need to connect the red wire that comes from the CDI that is in the same connector as the black kill switch wire. The old CDI got power from a wire that ran from the regulator but that wire came out with the old harness. If someone has installed one maybe they can give me some help.
spoke192 is offline
Tags
cdi , ignition problem , sportsman 600
Replacement bulbs Bigriver ATV Visual & Body Modifications 7 07-17-2010 02:25 PM
4x4 coil hub replacement frankescrambler ATV Repair and Maintenance 4 01-09-2010 06:55 PM
CV joint replacement Makxc50099 ATV Repair and Maintenance 10 12-03-2009 05:34 PM
Looking at a few replacement ATV's dragon71 ATV New Members 8 07-08-2009 03:35 AM
Cooling Fan Replacement sleepless ATV Repair and Maintenance 4 06-18-2009 03:50 AM
