2003 500 HO wont start - Polaris ATV Forum
Old 03-07-2011, 03:32 PM
harligreg's Avatar
Member #12710
Smile 2003 500 HO wont start
I started it up to run it and keep the battery charged ! It started right up , rode it for 3 or 4 minutes and it shut off . That was a few weeks ago . Since then I have checked for spark ,changed plug . checked valve timing and spark timing , Plenty of battery and comp. was full of gas ! Whats going on ?? It was always a good running mach. , was running great just before it shut down !
Old 03-07-2011, 08:25 PM
Old 03-07-2011, 11:02 PM
Stealthepooty's Avatar
Member #6542
Always the basics.
Is it getting Spark? (yes)
Is it getting Air?
Is it getting Gas?
Try taking the air filter off and dump a tiny bit of gas in the intake to see if she fires at all.
_______________________
2010 Polaris 850 XP, Warn XP-30 Winch, KFI Winch Mount, Steel Front & Rear Rack Extenders
My neighbor called the cops because I was playing Radar Love too loud.... they arrested him.
Old 03-08-2011, 03:55 AM
Cslaxer26's Avatar
Member #12427
I keep having the same problem with my 700 i let it sit for a week because of bad weather and then it wont start. I charge the battery and then its fine.
2003 Polaris Sportsman 700 Twin
.Modified Front Brush Guard
.Rear Brush Guard
.2500 lb. Warn Winch
_____________________________________________
2002 Polaris Sportsman X 500 HO(The Workhorse)
.52 in. Snow Plow
.Polaris Rear Brush Guard
Old 03-26-2011, 05:55 PM
7.62Addict's Avatar
Member #13356
Once in a while mine does that. Its usually is vaporlocked when hat happens. A
s mentioned earlier, give it a little gas. That is assuming you have already verifed your getting a hot spark.
Old 03-26-2011, 09:09 PM
harligreg's Avatar
Member #12710
Thanks for the come back guys !! I did it all , first thing I did was starting fluid , NOTHING !! I opened it up , timing chain OK , timing marks OK , checked valve clearance ( .006 ) intake & ex , magnetic pickup clearance to flywheel ,changed plug !
The gas that was in it ( full ) I put in about 2 weeks earlier . I have good spark at the plug when it's against the frame and I crank it , but put the plug in and NOTHING ! Also checked around air intake for air leaks !! The most I got was a small pop out of the muffler !
Old 03-26-2011, 10:04 PM
7.62Addict's Avatar
Member #13356
If you used starting fluid with correct timiing and it wouldnt start than you have no spark. Go back to the basics, the problem is probably very simple. I have a fair amount of exp with repairs after all I own a Polaris (only joking, but not really)
2001 polaris sportsman 500 ho no spark
2001 polaris sportsman 500 ho timing marks
2001 polaris sportsman 500 ho valve clearance
2003 polaris ranger 500 wont start has gas and spark
2003 polaris sportsman 500 ho no spark
2003 polaris sportsman 500 no spark
2003 polaris sportsman 500 valve clearance
2003 polaris sportsman 500 won't start
2003 polaris sportsman 500 wont start
2003 polaris sportsmen 500ho doesnt have spark
2003 polaris utv 1500
2003 sportsman 500 no spark
Wont start from a cold start. gramslam05 ATV Repair and Maintenance 5 11-28-2010 06:57 PM
2003 Magnum fan wont kick on mattb1974 ATV Repair and Maintenance 2 11-26-2010 05:31 AM
2003 trailboss wont charge dneuhof ATV Repair and Maintenance 1 07-07-2010 07:11 PM
2003 Preditor 500 wont start!! turns over has Spark PLEASE HELP Xukh ATV Repair and Maintenance 13 02-19-2010 07:06 PM
500 wont start sunshine Polaris Sportsman 7 10-02-2009 08:37 PM
