'98 Sportsman 500 carburetor kit - Polaris ATV Forum
post #1 of 11 (permalink) Old 03-21-2011, 09:34 AM Thread Starter
rowdyredneck's Avatar
Hi everyone,
New member here, I just bought a '98 Sportsman 500 that needs some minor work. One of the problems is its leaking gas out of the carburetor, but I can't find a rebuild kit anywhere. I've spent hours searching online but all I can find for the Sportsman are kits for a '94-'95 and '99-'00. I've looked up the OEM Polaris part number for the carburetor and the '99 uses a different number than the '98, but judging by the picture the gaskets look similar in shape to my carb. Does anyone know if the '99-'00 kit will work, or where I can find the correct one?
rowdyredneck is offline
post #2 of 11 (permalink) Old 03-21-2011, 07:03 PM
Bruce! is offline
post #3 of 11 (permalink) Old 03-21-2011, 07:58 PM
polman500 is online now
post #4 of 11 (permalink) Old 03-21-2011, 08:07 PM
Oh yeah, "Hit the Gas" is a supporting vendor of this site! If you don't do ebay, Phil can probably fix you up. Send him a PM.
post #5 of 11 (permalink) Old 03-22-2011, 04:24 AM Thread Starter
Thanks! I just bought one. I saw the kits for the Scrambler but I wasn't sure if they were the same as the Sportsman.
post #6 of 11 (permalink) Old 03-31-2011, 06:36 PM Thread Starter
I received the kit the other day, took the carb apart tonight and its the wrong kit. After more exhausting research it turns out this kit fits the '98-'02 Scrambler, and it appears the '02 Sportsman only. I've contacted the seller to arrange a return. I don't blame him for it, as the package even says its supposed to fit mine. I'm at a complete loss as to what to do next...absolutely nobody lists a kit to fit the '98 Sportsman 500. The closest thing I can find is for the '99-'00 models, which looks very similar to mine.
I found the leak at least. On the bottom of the carburetor bowl there is a screw with a tapered end. The gas is leaking past that screw and out through the hole in the bottom of the bowl. In the diagram below, its number 21:
Anyone know exactly what the purpose of that screw is? Only thing I can see it being useful for is to drain the fuel from the carb.
post #7 of 11 (permalink) Old 04-01-2011, 08:38 AM
That screw is to drain the float bowl only. It may just have some grit under it.
Here is a link to a kit at JetsRus:Jets R Us
post #8 of 11 (permalink) Old 04-01-2011, 08:42 AM
If you click on the "carburetor" tab and then "rebuild kits" it shows that same kit fits 98-02. You might want to contact them to make sure before ordering. I've done business with them before and they know carbs.
post #9 of 11 (permalink) Old 04-01-2011, 08:55 AM
Here's the link to Shindy's web site. They confirm the same kit number as Jets R us fits 98-02.
As I said before...most times a good thourough cleaning will cure most carb problems. Good Luck!
[ShindyPro.com] Shindy Products, Inc. : Catalog
post #10 of 11 (permalink) Old 04-01-2011, 09:48 AM Thread Starter
That Shindy kit is the one I have, part number 03-408. If you look at the application, the only Sportsman 500 it fits is the '02 model, plus it fits all '98-02 Scrambler 500s. Its completely different from my carb; the bowl gasket and most of the other parts are different. I think the only thing that might work out of that kit is the needle and seat, but that won't do much for my problem. I tried tightening the drain screw but I couldn't tighten it anymore. After removing it, it looks like the end is slightly deformed.
I ended up ordering a Moose kit for the '99-'00 model....didn't know what else to do. Judging by the pictures I saw of that kit it appears most or maybe all of the parts are the same as mine, but I won't know for sure till I get it. If all else fails I'll just have to epoxy the drain hole shut. I can't see any reason I'd ever want to use the drain screw anyway. Thanks for the suggestions.
2005 Sportsman 700 Carburetor Removal Breakineven ATV Repair and Maintenance 5 01-09-2015 01:28 PM
need carburetor 98 sportsman 500 weldpro78 Polaris Sportsman 1 10-14-2010 11:14 AM
98 sportsman 500 carburetor weldpro78 ATV General Discussion 0 10-14-2010 10:42 AM
2000 sportsman 500-carburetor help kevinde1 Polaris Sportsman 2 09-29-2010 02:02 PM
04' sportsman 500 carburetor JC DADDY Polaris Sportsman 4 04-20-2010 04:19 AM
