03-31-2011, 10:01 AM
Member #6539
how to remove front driveshaft ??
need to replace ujoint on front shaft and rear yoke hitting trans housing do i need to lift motor or is there a trick ??? thanks
2005 camo hunter edition sportman 800 27inch 589s
03-31-2011, 10:27 AM
Member #5629
Welcome! To remove the front propshaft you will need to:
1. Remove the right front wheel.
2. Remove the roll pin that goes through the yoke at the front differential.(make sure to get a new roll pin)
3. Slide the propshaft toward the transmission to remove it from the front differential input shaft.
4. When the shaft comes off the diff input shaft, then pull the propshaft forward to remove it.
5. Installation is reverse of removal.
You can get the u-joint at Napa.(part # 338)
Hope this helps!
Con
03-31-2011, 12:48 PM
Member #6539
Yea I've tried that it's hitting the trans case does look like enough room to pull out
03-31-2011, 02:38 PM
Member #5629
It should go back far enough. You may have to move it forward and clean the tranny output shaft, then see if it will move far enough. Sometimes you have to wiggle or turn the propshaft to get to come off the front differential. Be sure to spray the tranny shaft with wd 40 or similar product.
Con
03-31-2011, 07:02 PM
Member #6539
i tryed everything the shaft slides very easy on imput shaft but when it hit motor housing theres still an inch to go i ended up leaving it on and replacing ujoint while one end still attached it wasnt easy but it done !!
thanks for the help
03-31-2011, 07:09 PM
Member #5629
Ok, I guess that's one for the record book!! lol Glad you got it fixed, too!
Con
01-12-2012, 05:28 PM
Member #22240
i have my drive off but cant get is slid out i tryed doing it in it still but have a socket stuck now i reall need to get it pulled out so i can put it in a press any ideas
01-13-2012, 04:33 AM
may have to un bolt front diff, there are 4 bolts in the bottom, aybe that will give you room
05 sportsman front drive shaft removal, 2005 polaris 800 twin rear drive shaft removal, front driveshaft removal 2010 polaris 800 hd, how do u get a drive shaft out of a polaris rzr, how do you remove a polaris sportsman front drive shaft, how to change a front propt shaft on a polaris sportsman, how to change a universal joint on a polaris razor, how to get front u joint out of polaris razr, how to remove a prop shaft on a 2001 polaris 500 sportman, how to remove the u join from a polaris 2001 sportsman, polaris front drive shaft, polaris rzr drive shaft, polaris rzr driveshaft removal, replacing reverse shifting shaft in a 2001 polaris sportsman 500, rzr drive shaft removal, rzr front drive shaft, rzr front drive shaft pin, rzr front driveshaft removal, rzr propshaft, stuck driveline rzr
