2005 500HO electrical problem - Polaris ATV Forum
post #1 of 11 (permalink) Old 04-13-2011, 05:01 AM Thread Starter
swva's Avatar
Question 2005 500HO electrical problem
I've got an 05 with some kind of electrical problem. I was using it to pull some brush, turned the machine off and went to restart it and it was completely dead, like there wasn't even a battery on it. I replaced the battery and still nothing. A short while later, I turned the key and it worked like it should. I turned it back off and now nothing. I have power to the solenoid but nothing else. Can someone help? I had the ECM replaced under a recall a few years ago.
swva is offline
post #2 of 11 (permalink) Old 04-13-2011, 05:49 AM
racer37l's Avatar
Welcome!
Does the display on the pod light up?
If it does, try tapping on the solenoid. If the bike starts when doing this, then you have a bad solenoid or just corroded connections on the solenoid.
Con
racer37l is offline
post #3 of 11 (permalink) Old 04-13-2011, 06:35 AM Thread Starter
swva's Avatar
no, nothing lights up. it's like there isn't a battery. I have power to my solenoid from the battery. I bridged it with a screw driver to see if it would throw it to my starter and it did. there is no power coming to the front so i'm thinking start small and simple with ignition switch, cluster on left side of handle bars, or solenoid.
swva is offline
post #4 of 11 (permalink) Old 09-27-2014, 04:30 PM
67galax's Avatar
Hi, new here. My dad's 2005 500HO is having the exact same problem. Did anyone ever figure this one out?
67galax is offline
post #5 of 11 (permalink) Old 09-27-2014, 05:03 PM
mvn
mvn's Avatar
Bad PDM I bet.
Mark
2012 850HO Touring EPS Pearl White
27" ITP XTR radials on 14" ITP SS212 wheels
Ricochet skid plates & A-arm guards
Rubberdown 1 1/2" lift
Cecco frame braces
JC Capri bushings
Rotopax fuel packs on custom mounts
Garmin 60CSx with Ram mount
Polaris 2500# winch with synthetic rope
Polaris front & rear brush guards
Polaris bar & thumb heaters
Polaris passenger grip heaters
NGK (6043) ILZKAR7A10 plugs
Good, fast, cheap.....pick 2!
mvn is online now
post #6 of 11 (permalink) Old 09-27-2014, 05:50 PM
67galax's Avatar
Are the PDM and ECM different?
I pulled off the front plastic and found a finned aluminum box, which I assume is the ECM. I pulled the plug off of it, and tried to check the voltage at each pin (or hole) in the plug (not the EMC itself). I couldn't find 12V anywhere. However, on a couple of the pins, my multimeter registered .03-.04V. Connected to nothing, the meter read 0.00, and only moved to .03-04 when I touched the plug.
There is also a black plastic box mounted just about the aluminum finned box. Is that the PDM?
(and I did test every connection on both kill switch plugs, with no voltage present either)
67galax is offline
post #7 of 11 (permalink) Old 09-27-2014, 05:50 PM
texbigred1's Avatar
Bad fuse or fuseable link wiggle the wires at the battery see if it will come on
2014 sportsman 570Efi. CAMO non eps
Polaris front bumper and rack extender
Home made hitch
3500lb badlands winch
Kfi Winch mount
Highlifter HD springs f&r
2000 sportsman 500 *sold*
2017 sportsman 850 high lifter
18in curved light bar.
Home made hitch
2 inch lift
texbigred1 is offline
post #8 of 11 (permalink) Old 09-27-2014, 05:51 PM
texbigred1's Avatar
Also check the connection on the back of key switch
Home made hitch
Kfi Winch mount
Home made hitch
2 inch lift
post #9 of 11 (permalink) Old 09-27-2014, 07:33 PM
mvn
mvn's Avatar
67galax, is your 05 a carb or efi?
Mark
Cecco frame braces
JC Capri bushings
mvn is online now
post #10 of 11 (permalink) Old 09-28-2014, 07:46 AM
67galax's Avatar
it is EFI
67galax is offline
2005 atp 500ho matty2244 Polaris Sportsman 5 04-14-2014 09:30 AM
2005 700 EFI vs 2010-11 500HO chrisnwmsu Polaris Sportsman 9 02-28-2011 04:25 AM
2004.5 Polaris Sportsman 500ho electrical problems Farnz Polaris Sportsman 3 02-14-2011 05:26 PM
2005 500 sportsman electrical problem srt2 ATV Repair and Maintenance 3 12-01-2010 03:27 PM
electrical problem 2005 sportsman help.... srt2 ATV New Members 2 11-28-2010 05:52 PM
