I have mounted two Super Winches so far. My buddies wife has one that still needs to be mounted...
On my pops 550XP (A 3500#model )I put it under the front box in one of the depressions and drilled two access holes for the wires.
On my wife's Trail Boss, (A 2000# model) I mounted it between the frame under the seat.
Find the spot as out of the elements as possible where the wiring allows. Just take your time laying out the wires, don't pull too tight and run the wires with some thought avoiding abrasions or movement that could loosen connections.
2007 Polaris Sportsman 700 EFI W/ 26" Maxxis Big Horns, Crusher Black alloy rims, EPI clutch kit, EPI HD springs F&R, Moose front/Ricochet rear CV guards, UNI air filter, Moose camo tank bag, F&R rack extensions, Lock-N-Ride lo & hi windshields, Acerbis hand guards, CUSTOM mirrors and a 3000# Gorilla winch, W/Am-steel blue synthetic line, running thru a winch saver and an aluminum fairleed. Thor's foot pegs and CUSTOM rear rack support frame and WES seat box. CUSTOM front and rear mud flaps.
NEW: CUSTOM SIDE MOUNTED 1.5 Gal Kolpin gas cans & 800 dual Exhaust.
