Old 05-07-2011, 06:24 PM
mikertldg's Avatar
Member #14824
2010 500ho clutchin
I am just wondering if there are any settings or a adjustment on the primary or secondary clutch on a stock unit?
Old 05-07-2011, 06:37 PM
cwlongshot's Avatar
WELCOME,
NOPE.... There is nothing to adjust... There are some parts that can wear with time and mileage. You can install a different spring to change RPM engagement or some weights to work with the belt grip... But no there is nothing to adjust.
2007 Polaris Sportsman 700 EFI W/ 26" Maxxis Big Horns, Crusher Black alloy rims, EPI clutch kit, EPI HD springs F&R, Moose front/Ricochet rear CV guards, UNI air filter, Moose camo tank bag, F&R rack extensions, Lock-N-Ride lo & hi windshields, Acerbis hand guards, CUSTOM mirrors and a 3000# Gorilla winch, W/Am-steel blue synthetic line, running thru a winch saver and an aluminum fairleed. Thor's foot pegs and CUSTOM rear rack support frame and WES seat box. CUSTOM front and rear mud flaps.
NEW: CUSTOM SIDE MOUNTED 1.5 Gal Kolpin gas cans & 800 dual Exhaust.
Old 05-07-2011, 06:52 PM
mikertldg's Avatar
Member #14824
ok well i dont like how high it revs so should a guy put a weaker spring in or a stronger one? I ride roads and do some muddin as well! My tires are mud tires but same size as the stock ones if that makes a difference! the rest is stock
Old 05-07-2011, 07:25 PM
27x10x12 fit on front 2010 500ho slimmer ATV Wheels & Tires 8 09-26-2012 02:52 PM
HELP 2010 500HO Tranny Knock grizzly ATV Repair and Maintenance 6 04-17-2011 04:06 PM
2005 700 EFI vs 2010-11 500HO chrisnwmsu Polaris Sportsman 9 02-28-2011 04:25 AM
My 2010 500ho dont like the winter Zipper ATV General Discussion 10 01-19-2011 05:01 PM
Drive Belt on 2010 SP 500HO help skiingmaniac00 Polaris Sportsman 0 08-12-2010 12:14 PM
