gas coming out overflow tubes - Polaris ATV Forum
Old 05-26-2011, 08:56 PM
polariskid13's Avatar
Member #15173
with a full tank of gas i noticed gas came out the overflow hoses on the bottom of the frame wasnt alot but enuf happened when trailering it just wonderin if its normal but the thing moves alot on the dirt road we were on thanks for your help
Old 05-26-2011, 10:05 PM
MadMikeDt's Avatar
Member #15276
Could be your float is stuck in the bowl of your carburetor
Old 05-27-2011, 04:37 AM
what machine ? turn gas off when not in use
Old 05-27-2011, 05:11 AM
cwlongshot's Avatar
What are you calling "overflow tubes"?
There are vent lines on the top of the carb and a bowl drain at the bottom. If yours is carburatated. Then there is vent lines for fuel tank.
If working properly, None should expel fuel.
Let us know where you found the fuel escaping.
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
Old 05-27-2011, 05:28 AM
SMP63's Avatar
Member #13545
Mine does the same thing if i fill it up before trailering. I figured out its the the vent line from the fuel tank. The vent line is routed up thru the pod before going out the bottom of the wheeler.
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 05-27-2011, 06:13 AM
Member #15173
thanks for the replies i think it is as posted above^^ with the fuel tank vent cuz on the way home with just over half a tank none came out
Old 05-27-2011, 07:04 AM
Member #15173
i dont think its the carb bowl as it only happens when trailering and it doesnt come out when riding
Old 05-27-2011, 07:16 AM
bgirard420's Avatar
Member #11494
x2 on the tank vent line. I've even seen fuel sloshing around in the line right after filling up and riding. Russ is right, you should always close the petcock when trailering although this won't help with tank vent reflux.
2013 Polaris XP 850 HO LE EPS
2010 Polaris 500 HO
Old 05-27-2011, 09:53 AM
jayhkr's Avatar
Member #8079
Same thing happened to me one time. Freaked me out, I also had gas in the air box. The petcok was off during transportation, just emptied the air box and was good to go.
2001 Sportsman 500 HO 4x4:
K&N Filter
Warn 2500# Winch
Heated Hand Grips
60" Polaris Razor Plow
26" Mud Lite XL Tires
Aftermarket Wheels
2008 Sportsman 300 4x4:
Upgrades soon to come!
Old 05-31-2011, 05:06 PM
Member #15173
took it for a rip and a lil gas was in the tube again kinda crappy wastin fuel it shoudlnt come out the tank vent that easily
4 wheeler leaking gas out of tube on bottom of carburetor
84 polaris carb leaking gas
fuel is coming out overflow on atv
fuel vent line on a 2007 polaris sportsman 90
gas coming out of overflow on atv
gas coming out of overflow tube on atv
gas over flow line on 2002 polaris 700
overflow leak on polaris 250
polaris four wheeler fuel leaking overfill
polaris overflows gas out tube
what is the clear tube on a 2007 polaris sportsman 90
why does gas come out of my polaris indy seat
Coolant leak/overflow? swcheese ATV Repair and Maintenance 2 02-14-2012 05:22 AM
2 tubes hanging? normal? - 2011 sportsman 500 HO MudLife500 Polaris Sportsman 16 01-19-2012 09:08 PM
Clear tubes running into the pod on a 2007 800 EFI? Matchbox73 ATV New Members 3 03-05-2011 07:37 PM
Vent tubes from carburator craigooo Polaris Trail Blazer 11 01-05-2011 09:42 AM
Clear Tubes under the seat Bueller218 ATV General Discussion 4 07-13-2010 05:25 PM
