Tire pressure - Polaris ATV Forum
Old 05-31-2011, 12:33 PM
Mik's Avatar
Mik Mik is offline
Member #15255
Tire pressure
I have a new 2011 sportsman xp with the AT 489 II tires. The tire says max pressure is 17 pounds but what do most people run on them? Less then the max? I guess a better question is how little can you run without worrying about break the bead?
Mik
Old 05-31-2011, 12:45 PM
cadpat's Avatar
Member #9679
Mik
Manual saids 5 PSI for all tires I think.
2015 Sportsman 570
2011 Sportsman 400 HO
Old 05-31-2011, 12:53 PM
Yeah, I think 5-7 is pretty normal for all 4.
The max psi is just when installing the tire and trying to seat the bead on the rim. Not anywhere close to the psi you actually want to run at
Old 05-31-2011, 01:48 PM
Action's Avatar
Member #14212
Agreed, mine came with the 498's also and I ran them at 6 psi.
Action
2011 850 XP EPS Camo
A Arm Guards F&R
F&R Storage box
GBC Dirt Commanders
ATV Guru Brush Guard F&R
Ricochet Skid Plates
UNI Air Filter
2013 RZR 570 LE
Half windshield
Sport Top
More to come.....
Old 05-31-2011, 03:37 PM
novaroam's Avatar
Member #13345
Mik
My dealer claims I should run 10 lbs and a little more if riding rocky areas. I asked him twice about this and he was adamant about it.
Old 05-31-2011, 03:55 PM
cwlongshot's Avatar
Tire pressure, correct tire pressure is based on what your riding on, how you ride and the weight the machine is carrying. There for, its near impossible to give you an accurate "number".
Having said this, 17# of air is way too much and as stated is just for seating a bead.
I suggest, something less than 10 to as low as 4# depending on terrain.
Less air gives you a bigger footprint, but doesn't allow for as much speed. It will also allow for side wall pinch and higher possibility for "popping" a bead. Riding at higher speeds with extremely low pressure can cause unsafe handling as well. Tire wear/ the tires life span at these lo pressure will be more rapid/shorter too.
Too much air, gives a smaller footprint, smaller means the tire is not able to "envelop" the terrain. Causes excessive throttle to try to compensate causing more ground disturbance. This is where the TREAD LIGHTLY credo comes in. Personally, I like: "Slow as you can, fast as you have to." In jeeps, tire pressure can be the difference between concurring a obstacle or not conquered it. Higher pressure will cause wear in the center of the tire. (Remember the smaller footprint)
Long story short, get a small compressor and try a couple different pressures and see for yourself the difference. Pick a number and go... Your best "starting n number" will be a riding buddy riding the same terrain that rides simularly to you and is on a simular machine.
If your a bigger guy start higher, if your a string bean lower. More stuff in the ranks, add some air, savvy?
2015 RZR 900 Trail BLK. Pearl
Lock N Ride roof
Lock N Ride 1/2 windshield
Lock N Ride rear box
LED lights front, top & rear
LOTS more coming...
Old 05-31-2011, 04:22 PM
MUDDIE49's Avatar
Member #858
I run around 5psi when i have my 489's on...remeber this the more air you run the less tire will hit the ground...so, i'd say 5 to 7 psi....there should be a sticker on your rear wheel fender thats has it...Muddie49
2009 Polaris 500 HO
Front&Rear Brush Guards
2500lb Polaris Winch
2" Ez install lift kit
Front &Rear Extenders
Polaris hand guards
K&N airfilter box system
My FenderGuards
EPI Clutch System. 2010 camo
SunPro Temp gauge. 550xp Sportsman
Xbow Gripper mount
~DOWN&DIRTY~
Old 06-01-2011, 01:22 AM
Dbez1's Avatar
Member #10159
I agree with most others...4-7 depending on terrain and your weight. Make sure they are all the same (within 1/4 pound) or the bike will pull to one side. You should have received a low pressure gauge with the quad. If you ride more aggressively, you will need to use more air to prevent breaking the bead. A more moderate rider can run less air and enjoy a smoother ride. Longshot's information above was very good. Enjoy your new quad!
2011 Sportsman Touring 850 (current)
2006 Outlander 400 (Sold)
2001 Sportsman 500HO (Current)
1997 Explorer 500 (Traded)
1998 Sport 400. (Sold)
1994 Trailblazer. (Sold)
198? Suzuki Quadsport 230. (Sold)
197? Yamaha YZ225 Three-Wheeler (Traded)
Old 06-01-2011, 05:26 AM
Fishy's Avatar
Member #10336
I run 2-3 psi in the winter if I have the tires on and 4-6 psi in the warm months depending on conditions.
A four-wheeled adventure will soon bring you happiness.
2014 Black Pearl Rzr XP 1K (stock for now)
Old 06-01-2011, 08:36 AM
Dbez1's Avatar
Member #10159
Fishy...I also run 2 pound of air on my 01 in the winter but that's because my old Gators have become so hard. When I run with tire pressure that low, I really need to keep an eye on them because it's easy to go from 2 pounds to 0 pounds. I didn't mention this earlier because I don't want to complicate the issue for a new rider. I'm due for new tires on the 01, and if I can find someone getting rid of lightly used 12" stockers, that will be good enough for what I use that quad for. Have a good day!
2008 polaris 90 tire air pressure
air psi in ranger atv tires
best tire pressure for a rzr 800
dirt commander tires air pressure
how much pressure should i keep in my polaris ranger tires?
polaris 530 correct tire pressure for stock tires
polaris rzr tire pressure
polaris sportsman 90 tire pressure
polaris sportsman tire pressure
rzr 570 tire pressure
stock tire pressure for a rzr 570
what tire pressure should i run in my atv
Tire pressure duffer Polaris XP 7 03-16-2011 07:53 AM
Tire Pressure Question Klimbimm ATV New Members 9 12-04-2010 08:18 PM
Tire air pressure gauges Cableguy657 ATV Repair and Maintenance 5 07-03-2010 07:02 PM
The importance of tire pressure! armycopter Polaris Sportsman 17 05-24-2010 10:51 AM
Tire pressure nmpolaris Polaris Sportsman 5 04-09-2010 06:56 PM
