How to change between Digital Spedo Settings - Polaris ATV Forum
Old 06-01-2011, 09:25 AM
DCT1984's Avatar
Member #13740
I have a 2004 Sportsman 700 twin (non EFI). It has the digital dash spedo which has a setting for what gear you are in, tach, milege and trip. It is currently set to what the tach is, how to you change the dash so I can see the milege and trip or how do you cycle throw the modes? I have looked all over the headlight pod where the spedo is but can't find a way to change it.
Thanks in advance!
Old 06-01-2011, 09:46 AM
Nwcid's Avatar
Member #14486
Your reverse override button should say "mode" also.
John
2010 800 EFI Sportsman 6x6
Black Vision 159 wheels
GBC Spartacus tires
Warn RT 30
Custom ATV-Guru bumper
ATV-Tec gun rack
2002 500 Sportsman 6x6
Titan 589 MT tires
Warn 2500 winch
Warn bumper
Cycle Country plow
Old 06-01-2011, 10:15 AM
DCT1984's Avatar
Member #13740
Nice... So I should hit that reverse override button while it is running and in the park gear and it should change? Thank you, I knew there must be a way!
Old 06-01-2011, 10:25 AM
191185's Avatar
Member #15311
While we're on the subject, what does that little dial do on the right side near the bottom ? It appears to spin alot, does it just change the angel of the handlebars >?
I also did not know how to change the speedo, thanks ! does that also show engine hours as well ?
Old 06-01-2011, 10:42 AM
Yes, the yellow button will cycle your display to engine hours.
The round dial is an up and down adjustment for your high headlight beam that is in the pod
Old 06-01-2011, 11:45 AM
191185's Avatar
Member #15311
holy cow, I'll have to check my high beam now, thanks !
Old 06-11-2011, 01:48 PM
twiststar's Avatar
Member #14279
spedo error
while we are on the topic of the spedo, sometime where it desplays the gear your in, its blank, even when in gear, and more recientaly it is now reading E all the time now, any ideas thanks
02 sportsman 700 twin,
2004 polaris sportsman 500 tach display
2005 sportsman 700 800 odo setting
2006 polaris 700 tach setting
how to change digital odometer reading on 2004 polaris sportsman 700
how to change odometer on a 2010 polaris sportsman
how to change the odometer on polaris sportsman 500
how to change the setup of speedometer on a polaris atv
how to display rpm on polaris sportsman
how to reset a speedometer on a atv polaris sportsman 400 2004
how to use the trip odometer on polaris 2008 sportsman
how to use trip tach on polaris 500
switching display on polaris 500
03 Sportsmam 600 Did an ignition/stator kit, now see statr on digital display steelhead ATV Repair and Maintenance 8 09-15-2012 09:57 AM
2002 Sportsman 400 spedo/lights ? Dominant Predator Polaris Sportsman 3 05-27-2011 06:29 AM
Digital fuel gauge disapeared oppydog Polaris XP 4 02-07-2011 10:29 AM
Suspension settings tinman5255 ATV General Discussion 4 04-13-2010 06:11 AM
digital dash display. Craezy Polaris Sportsman 1 09-10-2009 09:32 AM
