Old 06-13-2011, 02:47 PM
polarberg's Avatar
Member #15708
Bendix or starter drive rebuild?
Starter spins but no flywheel engagement and the pull rope is brown, not too hard figure out that there is rusty water in there. Pulled the cover and everything is OK but dirty and rusty. Got the bendix apart and all is good, needs a soak and some wire brushing. Question: The spring that holds the centrifugal weights, I see this:
SPRING, WEIGHT ("J" Model Only)
NOTE: SPRING, WEIGHT 3084411 1 $9.72
Does that look like the spring?
1999 sportsman 500.
bendix drive repair
how to rebuild starter bendix
how to rebuild starter drive on polaris
polaris 3084411
polaris atv bendix drive
polaris atv starter drive
polaris bendix repair
polaris bendix spring
polaris starter bendix
polaris starter drive
polaris starter drive problems
polaris starter drive repair
polaris starter rebuild
starter bendix problems
starter bendix repair
problems with starter bendix kawastang ATV Repair and Maintenance 2 07-17-2012 08:10 PM
A Different STARTER BENDIX Issue....! Grouper ATV Repair and Maintenance 1 04-09-2011 05:57 PM
starter bendix peterman Polaris Sportsman 5 09-16-2010 08:24 PM
bendix and starter issues tim63 Polaris Sportsman 10 04-11-2010 05:19 PM
starter drive /bendix bomberboat ATV Repair and Maintenance 0 01-20-2010 06:18 PM
