Old 06-19-2011, 02:42 PM
kdsberman's Avatar
Member #2263
New guy..engine start problem
Hey guys. New here. I have a 2008 Sportsman 500 EFI that recently Im having trouble getting started. I bought it in 2009 new to use for ice fishing, so I currently only have around 100 miles on it. At first, when I turned the key to the "on" position, the computers would kick on like normal, but then it would make a slight clicking noise, then fire up normally. Now, when I go to start it, it makes more of that clicking noise and either might or might not start. Sometimes, turning to the "on" position it might not do anything.
Whats going on? Im not very knowledgeable on the "guts" of the 4 wheeler, but hopefully will as time goes on. Is my battery getting bad? Loose connection possibly, and if so, what could it be? I managed to get it running today, and every time I went to start it later it worked fine, but its pretty much after its been sitting for a few days.
Also, just a quick question on the fan/cooling system. Is the fan supposed to come on at all times the engine is running, or only when it gets too hot. And I noticed when my fan WASNT running, the coolant wasnt flowing either. Does the coolant only flow when the fan is running?
Thanks for the help guys, I know i sound like a rookie. I just want to keep my machine running as good as I can.
Old 06-19-2011, 02:58 PM
cwlongshot's Avatar
Good afternoon,
The starring troubles are very likely the battery as you suspect. Get a charger on it and let it charge at the very least overnight and see what you get. (BTW, Charging longer on lower amperage is better.)
Get yourself some Sea Foam and use it!! The other issues with many machines if the fuel system, we don't drive them all the time so they sit more than they run, this spells problems for the fuel system. ESPECIALLY with the new shit fuels today. Sea Foam will correct the problem and keep it from happening again.
The fan should only run when the engine reaches a high(ER) temperature. It should NOT be running all the time.
Old 06-19-2011, 05:14 PM
kdsberman's Avatar
Member #2263
Thanks CW. So I'm assuming that the coolant only circulates when the fan is running?
I'll have to try some Sea Foam.
The weird thing is that when I had my key turned to "on" with nothing happening, and when I started wiggling some wires it all of a sudden kicked on.....BUT still "clicked" when I try starting it.
Old 06-19-2011, 07:55 PM
1of7627's Avatar
Member #4155
Coolant circulation isn't related to fan operation. Coolant is circulated by a mechanical pump that operates when the engine is running, so coolant should always be flowing. Early two-strokers didn't have thermostats, but later models (4-strokers) do. As CS says, the fan only operates when the coolant reaches a pre-set (hot) temperature.
MarkC - Spokane, WA USA
Old 06-20-2011, 03:53 AM
check and clean connections at battery then take wires off selenoid n check nuts under wires for tightness then clean and replace wires
Old 06-20-2011, 04:40 AM
kdsberman's Avatar
Member #2263
Ok, thanks guys. I'll have to try that.
Ya i was just curious about the coolant because as my machine was running I got off and looked under it and it looked like the coolant was just sitting there.
Old 06-20-2011, 03:40 PM
ppolaris1010's Avatar
Member #15104
thats your overflow jug your probably looking at just like your car has you wont see it move the level will rise when its hot and lower when it cools down if the jug is empty then you have a leak
700 polaris sportsman starts sometimes
hawkeye forwhweeler starter making clicking sound
hawkeye forwhweeler starter making starting problem
nothing happens when key is turned on polaris
polaris 4 wheeler just clicks when key turned on
polaris 4 wheeler trouble starting
polaris 50 4 wheeler clicks when go to start
polaris four wheeler not starting just clicking
polaris sportsman 700 clicking
polaris sportsman 700 only runs in start position
polaris sportsman 800 just clicks will not start
polaris sportsman just clicking when key turned
polaris sportsman repeated clicks sometimes starts
starting a polaris sportsman 600 4 wheeler
engine problem popo7 ATV Repair and Maintenance 5 04-26-2011 07:46 AM
Engine Problem silveradoblk ATV Repair and Maintenance 2 11-25-2010 06:50 AM
Engine Problem silveradoblk ATV Repair and Maintenance 0 11-24-2010 06:12 PM
No Fuel - To start engine itscody ATV Repair and Maintenance 5 06-19-2010 02:51 PM
Engine start issues cold dirtdobbercracker Polaris Sportsman 0 12-19-2009 08:07 PM
