06-20-2011, 12:31 PM
Member #9026
Tires and wheels
Im thinking about getting some new tires ans wheels for my sportsman. I think I want the Maxxis Bighorn or the superATV's Dominator tire on some ITP SS212 wheels.
Where is the best place to get tire and wheel combo's? I notices there are a couple sites that have about $100 price difference on the wheels...
are there better tires than what I have picked? Any help would be appreciated
Lead, follow, or get out of the way. -Thomas Paine
06-20-2011, 02:21 PM
Member #14486
Better tires would depend on your riding style. For me I do a lot of "trails" or soft pack roads, some hard pack when I do rides with groups and friends, I like to play in the mud and want good traction on lose ground since I like to climb stuff. Of course snow plowing traction is a must too. A must for me was a tire that would be able to run even when flat which means at least a 6 ply sidewall, I ended up with an 8 ply this time.
After doing a bunch of research I ended up going with the GBC Spartacus cause they fit the use I wanted. They are a tight enough tread to run smooth on hard stuff but open enough for the lose traction. I only have a couple hundred miles on them so far but I am very happy. I went with a Vision 159 wheel. I got mine from a supporter here, Discount tire. Nice thing is they come all mounted ready to go.
John
2010 800 EFI Sportsman 6x6
Black Vision 159 wheels
GBC Spartacus tires
Warn RT 30
Custom ATV-Guru bumper
ATV-Tec gun rack
2002 500 Sportsman 6x6
Titan 589 MT tires
Warn 2500 winch
Warn bumper
Cycle Country plow
06-20-2011, 03:02 PM
Member #5589
I just new wheels and tires on my XP. I went with the ITP XTR and ITP SS-312. And I'm loving them
06-21-2011, 11:54 AM
Member #9026
Thanks for the input guys!
I just got back from the dealership. Now, normally I always order online, but this dude cut me a deal I couldn't refuse, at least I think its a good deal :P
I bought these:
ITP SS108
and these:
Maxxis Abuzz (similar to the Big Horns)
also I thought I needed this:
full exhaust. Evo Big Gun
I went with these tires for a few reasons, I ride everywhere, except super deep mud, and I dont "go deep" I need something for soft, hard, loose, and sand. It appears this type is best for that. I chose these over the Big Horns because with the shouldered lugs they are supposed to be better at cornering.
I had a hard time deciding between the SS212 and the SS108, but EVERYONE has the 212's.
I know what I'm going to be doing this weekend :P
06-22-2011, 01:58 PM
Member #15357
I need help:::: I bought a set of 2011 polaris xp 550 wheels for my 2008 500 ho what do i do to make them work that dont cost very much!!!!! Thanks for help
06-22-2011, 02:03 PM
Member #9026
Why do they not fit? Different lug spacing? Or does the rim rub on any components?
06-22-2011, 02:46 PM
Member #15357
They dont fit because of studs to short and they pop off the center cap by the axle nut. They are the right bolt pattern
06-22-2011, 02:50 PM
Member #9026
Maybe someone would know more than me, but it sounds like wheel spacers might do the trick.
Polaris Sportsman : ATV Wheel Spacers : Super ATV LLC
Call those dudes, they can help you out.
06-22-2011, 02:51 PM
They don't fit because of studs to short and they pop off the center cap by the axle nut. They are the right bolt pattern
You have studs designed for steel rims, Thor or one of the other site sponsors can hook you up with longer studs designed for ALLOY rims!
Drop them a line...
As for the tires, I have 26" Maxxis BigHorns and love 'em!!
Member #15357
Thanks i will call.
30 dominator tires, atv maxxis abuzz tires forum, atv tires and wheels, atv tires and wheels for polaris sportsman, atv tires polaris abuzz, best place for rims and tires for polaris sportsman, bighorn dominators, dominator bighorn tire, dominator tire and rim combo kit, maxxis bighorn tires versus dominator tires, maxxis bighorn vs superatv dominator, polaris ranger with 30 dominators, steel wheels atv polaris sportsman lug spacing, stud tires maxxis bighorn, super atv dominator vs bighorn, superatv dominator tire, superatv dominator tires, vision atv wheel 159, vision atv wheel pics, vision atv wheels
